#3 cylinder - 0 compression
Old 19 Dec 2013, 02:23 pm
Default #3 cylinder - 0 compression
Have a 2003 LE, 141k miles. Took it to the shop for a blinking CEL and they're telling me the #3 cylinder has no compression and they need to pull the head to determine the extent of the trouble.
Wondering (hoping) if there's a chance it's a stuck valve and can be remedied with an additive since there's no way I can pour $1200 into this car.
Anybody have any experience that might be helpful?
Old 19 Dec 2013, 02:37 pm
Default Re: #3 cylinder - 0 compression
No, but if you are so inclined, simply spend the couple bucks on the additive and see what happens. I don't hold out much hope for that, but if it will make you feel all warm and fuzzy inside knowing you tried, go for it. Like I said, you'll only be out a couple bucks.
Moving on now.
Jerry
Old 19 Dec 2013, 05:53 pm
randyincctx's Avatar
Cool Re: #3 cylinder - 0 compression
If you have 'zero' compression,the chances are it is a 'stuck' valve,if it was a 'sticking' valve,an additive might be a nice temporary fix.......But,once a valve is already stuck(open or closed),I don't see an 'easy fix'.
If still looking for hope,you might want to take a glance at this for suggestions:
Sticking valves, need quick fix. What to use? | Oil Additives | Bob Is The Oil Guy
Aka:~KILLER~
Old 19 Dec 2013, 06:35 pm
UptownSport's Avatar
It's much more likely a burnt valve, they're really not very expensive, but include removing the head.
Old 20 Dec 2013, 03:45 pm
Pulling the valve cover off isn't difficult or expensive, so it wouldn't be a big deal to do that and see what's going on. I gotta believe if they've already done a compression test you're 80% of the way there anyway - pulling the valve cover would just be a matter of sliding the power steering reservoir to the side and removing a few bolts. A stuck valve would be fairly easy to diagnose at that point.
Old 20 Dec 2013, 05:06 pm
cruserdad1976's Avatar
what they said pull the valvue cover and see if its moving
Compression Papa2448 General PT Cruiser Discussions 12 10 Jan 2016 12:15 am
No Compression in Cyl 4 WildBronco General Turbo Discussions 3 24 Oct 2013 04:14 pm
compression psi moonshinehd Tech & Performance Forum 7 27 Apr 2012 10:03 pm
Compression ptnut Tech & Performance Forum 12 21 Nov 2011 11:40 am
compression fittings Punch Exterior & Interior Styling 10 11 Nov 2003 10:36 pm
