Help! What Size Bolt Do I Need For Battery Hold Down Clamp???
Old 19 Dec 2013, 02:37 pm
Exclamation Help! What Size Bolt Do I Need For Battery Hold Down Clamp???
Hi all,
What size bolt does the Battery Holdown Clamp that holds down the back of the battery use?
I lost that bolt when I removed my battery to clean out the battery and the battery tray. I still have the bolt down black plastic clamp, but the bolt slipped from my fingers and fell "somewhere" in the area below the battery tray. (I am pretty sure the head is 1/2 inch - 13mm, I need to know length and thread please).
Unfortunately it did not fall to the ground.
So please, if you know where I can find out the size and threading of that bolt, PLEASE LET me know ASAP.
Thanks.
One more thing: Do I need the nut as well???
Doesn't the bolt screw into a permanently fixed nut underneath the battery tray???
2005 PT Cruister Touring
(No turbo or mods or anything like that)Attachment 9689
Old 19 Dec 2013, 03:00 pm
Default Re: Help! What Size Bolt Do I Need For Battery Hold Down Clamp???
This from my 2004 and 2005 parts lists:
Hex Head M8 x 1.25 x 55
No nut. The plastic tray has an attached panel nut, IIRC.
Originally Posted by myjeephatesme View Post
Hi all,
Doesn't the bolt screw into a permanently fixed nut underneath the battery tray???...
Old 19 Dec 2013, 03:17 pm
Thanks so much for the note. This is a real life saver.
Question: Do they have a washer as well??? That might have fallen through as well so I don't remember if it has a washer or not.
Old 19 Dec 2013, 03:37 pm
No washer on the stock bolt but it has a shoulder. A small washer won't hurt
what size are the sway bar clamp bolts??? 32seventeen Wheels, Tires, Suspension 4 27 Jun 2014 08:45 am
Need a battery clamp, where to get it? ProDigit General PT Cruiser Discussions 9 07 Jul 2011 06:54 pm
What size is this bolt??? hidinginparadise General Turbo Discussions 3 06 Mar 2011 07:59 pm
Need Battery hold down clamp hyltoto General PT Cruiser Discussions 0 10 Sep 2010 07:12 pm
Removing the battery hold down? deathchimp Tech & Performance Forum 11 07 Apr 2010 07:08 pm
