"HELP" Need advice--overheating??
Old 20 Dec 2013, 07:04 am
Default "HELP" Need advice--overheating??
Hi all, I have a 2001 PT Cruiser and after driving for 25mins the engine temp reached red and I pulled over, obviously a coolant circulation problem (water pump? Thermostat? Radiator? hoses?).
When I pulled over and turned the car off you could hear water bubbling away in the overflow tank.
I let the car cool down and checked the coolant level from radiator cap---no coolant!!!.
I then re filled the coolant with water (emergency situation-too far from auto shop).
Started the car and drove it home--25mins, the temp didn't go over half until about 1min from home.
Let the car cool down and purchased a new thermostat and coolant, fitted thermostat and coolant, bleed the air out and went for a 30min drive, temp never reached half until 25mins-overheated!!!
The Fan is operating correctly and radiator has no leaks.
Got the car home and lots of more bubbling hot water, opened the bleeder valve and nothing but steam.
On visual inspection, no leaks/no split hoses and thermostat is opening and closing.
Has anyone had this overheating problem---any advise please
is it my water pump!!!
Old 20 Dec 2013, 07:28 am
Default Re: "HELP" Need advice--overheating??
How many miles? At around 100,000 miles, water pump needs to be changed along with timing belt.
You can pretty well eliminate thermostat since you replaced it.
I'd be concerned with head gasket - what does oil look like? ( Take off oil cap and look in, look at dipstick).
Old 20 Dec 2013, 07:40 am
Car has done 179000Km, Timing Belt/water pump/tentioner all replaced aprox 6000km ago, oil changed 1000km ago, oil looks good.
Will not take car back to Chrysler dealership in Brisbane as after I had all this work done I noticed that they had broken the air-con compressor electrical connection and didn't do anything about it, I had a massive argument with them. Id say it broke when they lowered the engine to do the belt/pump.
Old 20 Dec 2013, 08:20 am
Welcome to the forum
How long have you had your pt?
Have you joined any local clubs?
Have you made any modifications to your pt?
What influenced you to buy your pt?
Feel free to post some pictures
Old 22 Dec 2013, 07:17 am
I had almost the same exact problem right after I got mine, ended up being the radiator cap, 5 dollar fix.
Old 22 Dec 2013, 11:49 am
You are from Oz?
You need to join here as well:
Recent Discussions - The Australian PT Cruiser Community
Engine coolant temp? How "hot" is overheating? Hearse Tech & Performance Forum 6 27 Jul 2013 12:52 pm
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
advice on "noise" on bumpy roads... comPuTer General PT Cruiser Discussions 1 24 Mar 2009 02:40 pm
