BEST PT UPGRADE??
Old 20 Dec 2013, 10:05 pm
Default BEST PT UPGRADE??
stock 04 PT non turbo..whats tthe best hop up or up grand for performance or the first?
I see hotter coils and wires out there?
thoughts ?ideals?
Old 20 Dec 2013, 10:42 pm
Handy_Cruiser's Avatar
Default Re: BEST PT UPGRADE??
thoughts ?ideals?
Good spark plugs and better wires are probably the best bang for the buck if everything is OEM right now. The OEM Chrysler coil is reported to be as good as it gets. So you likely wouldn't see any improvement by changing it.
That was my first upgrade. Read about it here:
The "Handy" Tune-Up
Old 20 Dec 2013, 10:59 pm
already done that thanks..Iguess maybe a new KnN FILTER SYSTEM?
Old 20 Dec 2013, 11:56 pm
WolfmanG's Avatar
if you want an aggressive sounding engine and a better throttle response then go with a short ram air intake, which what they really are but are sometimes called a cold air intake. but your best bet is to do an air box mod and use a k&n drop in filter. upgrade your exhaust system. full cat back with a chambered muffler. I had a Super 44 Flowmaster muffler on Eve(07 Touring ed n/a) but a fully exhaust system would've been better. i suggest going with a 2 chambered muffler but i think the cat backs that are made for our pt's come with a 3 chambered muffler. I would say use iriduim plugs, they can withstand heat better then copper or platinum's. definitely change your wires to 8mm or bigger. i know you said you already did that but what kinda plugs and wires did you use? other then that do waste time or money on anything else cuz that's all you can do to an N/A. maybe get some sticky tires like drag radials for better traction. other then that, maybe save up to get a turbo PT.
-Danny Wolfman G
Old 21 Dec 2013, 12:16 am
Yep, that would be the second thing to do. That's what I did. Read about mine here:
The "Handy" Air Intake Mod
Old 21 Dec 2013, 01:23 am
Best PT Upgrade?????
I vote for getting a Under Hood Strut Tower Brace!!
Old 21 Dec 2013, 08:43 am
tower braces? big improvement? what in lean? and were can I buiy the bigger wires?
Old 21 Dec 2013, 10:08 am
Tower strut brace? Many members report no improvement in handling, but a few report and noticeable improvement in stiffness. They are getting hard to find new, but there's plenty of used ones around. Some have to be modified to fit right. You can read about mine here:
The "Handy" NOPI Strut Bar Installation
On plug wires, the original plug wires have a reported tendency to break down over time and cause the engine to run rough. Many say 8 mm wires are best for replacement. Others say any quality after market set will do. If you look back to my tune up link, you will see the ones I used but those are not a direct fit. There's many to choose from. MSD Part#32689 is likely a top end choice.
Here's my strut bar:
Old 21 Dec 2013, 10:31 am
Easiest, cheapest thing you can do is pump up your tires - low tires make for sluggish acceleration and handling.
I put my tires 2-3 PSI over the driver door sticker recommendation (because they'll lose air).
Always check tires when cold (not right after you've been driving).
Old 21 Dec 2013, 10:34 am
A set of NS cams will give you power in torque and HP with no other mods. They can be transferred to a Turbo 2.4 should you do that in the future. Any other power augmented engine part will only add more then if the part by itself without the camshafts were installed.
big 3 upgrade dewey68 Sound and Security Forum 8 11 Aug 2012 02:53 pm
Looking to upgrade - Help? fotoguy General PT Cruiser Discussions 1 18 May 2011 08:11 am
upgrade my ecu jlamoros Tech & Performance Forum 10 12 May 2005 12:46 pm
BOV Upgrade Kit Fast04PTGT Turbo Performance 11 23 Nov 2004 04:12 pm
