Windows Switches Inopearble
Old 21 Dec 2013, 06:39 pm
soonercruiser's Avatar
Red face Windows Switches Inopearble
So, I've had the windows switch in/out, and disconnected/reconnected several times painting the center dash bezel, and replacing the VAC control bezel.
Now, this last time, the window switches for the 2005 Dream Cruiser vert do not want to work.
I have searched the fuse diagrams under the hood and dash.....but, nothing labeled for the "window switch".
The only thing close that I could find researching old threads was this....
Pwr Windows/Blower Fan/Back-up lights/Rear Window Defogger/Air Bag Light
Everything else near the dash, lights, wipers, HVAC controls...all work fine.
Any thoughts???
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 21 Dec 2013, 06:46 pm
Default Re: Windows Switches Inopearble
Frank,
I'm up in Virginia right now and don't have my Owners Manual for reference but I believe there's a relay (one of two) that are on top of the fuses in the interior fuse box and it's labeled "Power Windows". They are silver (at least in mine) so check that.
Old 21 Dec 2013, 07:02 pm
sanatanadharma's Avatar
As CREWZIN says, the power windows are protected by a large silver plug-in circuit breaker at the (likely) top left of the dash fuse-block.
Could also possibly be fuse #3 (40 amp) in the PDC.
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Old 21 Dec 2013, 07:28 pm
randyincctx's Avatar
Lightbulb Re: Windows Switches Inopearble
Check Interior fuse panel 'Circuit Breaker No. 2 (20A)',on the top left.....There should also be a 'Spare' next to it on the top right(maybe not).
Aka:~KILLER~
Old 21 Dec 2013, 07:31 pm
Attachment 9719
Attachment 9720
Holy Redundancy, Batman!
I beat you to it Busa.
Jerry
Old 21 Dec 2013, 09:13 pm
Red face Re: Windows Switches Inopearble
Attachment 9719
Attachment 9720
Thanks Crewzin and Santah,
Yes, there is one silver breaker at the top of the fuse box.
2 Problems....I 1) have no spare.....and 2) the fuse looks OK, as it is a black opaque plastic.
I don't see any way to tell if it is bad.
Randy,
Thanks for the diagram.
Just like mine!
Old 21 Dec 2013, 09:16 pm
Did you check the connector? Sorry but have to ask.
Old 21 Dec 2013, 09:45 pm
Not to worry....you can't insult this idiot!
Yup! Had it in & out twice.
I may try it again with some dielectric grease.
Old 21 Dec 2013, 10:29 pm
Unhappy Re: Windows Switches Inopearble
WHY ME?????
So, all the fuses look good.
I go back and pop out the switch panel and.....
Holy Crap!
The switch has come apart!
Obviously the problem.
But, the case and cover are part way off and jammed, with the switch poles leaning sideways!!!
When I do get this thing apart, I am going to need someone to tell me what hole numbers the contact blades should be coming out of!
I can assume that the poles/spades should be straight up vertically.
But, that may be assuming too much.
WHY MEEEEEEE????
Old 21 Dec 2013, 11:19 pm
Ouch!Looks like at least 2 of the spades might need a little soldering.
Aka:~KILLER~
Window Switches Badglas General PT Cruiser Discussions 10 30 Sep 2012 06:25 pm
Power window switches Barrels General PT Cruiser Discussions 10 12 Jan 2011 08:22 pm
Lighted Switches ?? h100250 Tech & Performance Forum 3 15 Oct 2009 11:20 am
Window Switches thegoldpt General PT Cruiser Discussions 15 12 Sep 2005 10:33 am
Interior switches deezel Exterior & Interior Styling 2 14 May 2003 08:56 am
