Head removal (for gasket change)
Old 22 Dec 2013, 01:33 pm
Default Head removal (for gasket change)
Hi all and merry christmas!!
I just started a head gasket change operation (yes, it is leaking a bit) and was thinking to try a slip and slide. Is there some special tools Iīm gonna need or can I manage with a set of normal tools?
Old 22 Dec 2013, 02:15 pm
Default Re: Head removal (for gasket change)
Hello Fin,
I have a 2005 PT and started the Head Gasket replacement yesterday. So far only normal hand tools but the Harmonic balancer is a bit of a problem. See this thread.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
So far this is the only problem I have encountered.
My PT Head Gasket was leaking oil from the rear of the engine. Why are you replacing the head gasket?
Phil
Old 22 Dec 2013, 04:59 pm
UptownSport's Avatar
I couldn't do it.
First, there's a brace from exhaust manifold to block you'd have to loosen.
The timing belt cover is bolted to the head, and the cover fits tight around cam gear bosses and idler.
It's nearly impossible to get headbolts between #1 and #2 cylinders loose with cams in place.
Once you take all that off, slip n' slide is kinda pointless.
Old 23 Dec 2013, 04:19 am
856666:
Gasket is leaking to coolant, bubbles and gas fumes in there. Also heats up.
New thermo and cap didnīt do the trick, fan works properly, aired up also. Most definately head (gasket) failure
UptownSport:
I noticed as well that the two bolts between cylinder 1 and 2 are are a problem. A bit tight spot. Havenīt found a proper tool yet...
If I find a tool for that, I will try to slip and slide. If not, maybe Iīll have to do it the right way
2001 Head Gasket change How-to d2freak82 General PT Cruiser Discussions 14 02 Dec 2013 02:41 pm
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? 06turbolite Tech & Performance Forum 8 14 May 2013 09:16 am
03 pt turbo oil in water new head gasket fresh head strokedoutss General Turbo Discussions 7 17 Apr 2013 04:22 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
