speedometer stopped working - p0500 code
Old 26 Dec 2013, 11:29 am
shelbyzman's Avatar
Default speedometer stopped working - p0500 code
We recently had an ice storm...so my pt sat for a day or so and when I hopped in to drive it to town the speedometer did nothing. It was still very cold and still had ice...this couldn't have anything to do with it could it? Anyway, the odometer, tach and all other gauges still work fine. After a day or so the engine light came on and it is showing the vehicle speed sensor code P0500. So is the speed sensor bad? If, so how hard is it to change and where is it?
2007 PT Cruiser GT • 5-speed • 17x8 Konig Inception wheels • K&N style intake • auto throttle body • Spec D tail lights • Blow off plate • 10.2mm plug wires • Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack • "blacked out" • DIY ground effects • added boost gauge (in place of analog clock)
Old 26 Dec 2013, 11:45 am
Handy_Cruiser's Avatar
Default Re: speedometer stopped working - p0500 code
There are two speed sensors located on the transmission. I would look first to assure they are plugged in and the wiring harness is intact. If so, the output sensor is often the culprit but not always. You will likely need to remove the battery tray to get at it.
1st-Gen Output Sensor:
1st-Gen Input Sensor:
Old 26 Dec 2013, 12:03 pm
shelbyzman's Avatar
thanks for the info! very helpful...hoping it just came unplugged or something
Old 28 Dec 2013, 12:51 pm
shelbyzman's Avatar
I just checked the code and it is p0501 not p0500....does this mean something different. By the way, my car is a 5-speed
Old 30 Dec 2013, 03:03 am
shelby; p0501 is also a code for the speed sensor. The picture shown is for an automatic trans. The proper socket [1" deep socket ?] makes the job easier.
AC stopped working realized Tech & Performance Forum 2 22 Jun 2011 06:06 pm
key fob stopped working twotone General PT Cruiser Discussions 10 17 Jun 2011 05:47 pm
My ac stopped working. Help!!! salena Tech & Performance Forum 3 14 Oct 2009 10:56 pm
CD Player stopped working ajc3 General PT Cruiser Discussions 5 18 Aug 2009 05:28 pm
