Idle odb2 values question
Old 29 Dec 2013, 04:52 am
Default Idle odb2 values question
Hello fellow PT cruiser owners. I currently own a 2002 PT Cruiser and I have a few questions that I would be grateful about if anyone could answer. (I also hope that this post could be helpful to others.)
Below are a few screen shots I've taken from an ODB2 scan tool that I've used on my car. My car was idle and parked while I gathered this information:
I understand most of the information present but I want to know if the values look normal.
I'm kind of concerned about the LTFT value, it seems a little bit high and I'm concerned that there is a potential problem like a vacuum leak.
Old 29 Dec 2013, 10:05 am
Default Re: Idle odb2 values question
Looking at the RPMs, I would say your ok on the vac leak. Nitro should know on the other reading.
Old 29 Dec 2013, 12:49 pm
UptownSport's Avatar
This means it's adding 10% fuel over what computer is programed.
Is it getting poor fuel economy?
Could be your conditions, cracked exhaust manifold or bad O2.
I'm not sure a vacuum leak would effect this- Closed loop uses the O2 sesnsor, not the MAP- MAP works in open loop.
Old 29 Dec 2013, 01:21 pm
I would say replace the HO2 and also do a compression test. You will probably find normal wear nothing to get excited about? Even with these readings you would most likely pass the emission testing in California.
Old 29 Dec 2013, 09:18 pm
But isn't a long term fuel trim of +/- 10% within spec? (Thanks for your quick replies by the way).
High revs at idle, and mileage question Twister Europe PT Forum 2 02 Nov 2013 09:34 am
DTC 401, rough idle and dumb question v_dragon General PT Cruiser Discussions 1 16 Jan 2013 09:39 pm
Timing Belt Broke- Are Values Bent? ilzho Tech & Performance Forum 13 17 May 2012 01:37 am
New guy with another fan/rough idle question canders Tech & Performance Forum 5 13 Jun 2011 09:11 am
pt cruiser depreciation values - ouch! pppt03turbo General PT Cruiser Discussions 25 09 May 2007 07:00 am
