I probably already know the answer
Like Tree5Likes
Old 04 Jan 2014, 09:50 pm
Default I probably already know the answer
So, I have a coolant leak that I see dripping down at the front of block just behind the timing belt cover. It is visible on the firewall side of the block, meaning I see it by crawling under the car and seeing it between the engine and firewall.
Is it a correct assumption that there is nothing else in that area other than the (ugh) water pump.
It is a 2007 2.4L NA manual transmission.
Thanks.
Old 04 Jan 2014, 11:02 pm
Red face Re: I probably already know the answer
get a flash light and look around u may get lucky and have a hose leeking or the thermostat neck could be?...if it is yr water pump then I"d go ahead and do the timingbelt and everything in there whil yr at it..and u can get the whole timing belt kit for around $120 shipped..Gates brand off ebay..save a bunch there..keep us posted on what u find? loosing much coolent?
Old 04 Jan 2014, 11:03 pm
Default Re: I probably already know the answer
mine was leeking just a small bit so I did a radaitor flush and filled it with water then it really leeked ..so u may check it that way but it cold out so save yr coolent..I know th water sure poured out of mine..
Old 05 Jan 2014, 12:15 am
Why would it only be seen on the firewall side of the engine when the water pump is on the radiator side?
How many miles on the car and is it the original water pump?
______________________________________________
Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean?
2001 PT Cruiser LE 5 spd, original owner, no mods, MOOG arms with spherical bushing (ride is now a bit harsher vs OEM)
- 109K replaced timing belt/WP/tensioner/idler/crank&cam seals with same 1st gen design. That was a fun day and half!
- 119K Gates water pump failed after only 10K miles. Replaced with Airtex. This time around it was a 7 hour job.
2001 PT Cruiser LE AT 59K miles. Bought used, newest addition to the family
Old 05 Jan 2014, 08:54 am
Freeze plug rusted thru???
Old 05 Jan 2014, 09:17 am
I'm thinking head gasket? A bit unusual. Coolant lines to either the heater core or turbo if you have that?
Old 05 Jan 2014, 09:50 am
2step's Avatar
Years ago, with a Dodge Caravan I had, a hose developed a pinhole leak. It was tough to find because the hose remained dry but shot a super thin, impossible to see, stream of fluid across a 2 foot gap to create a wet spot where the leak wasn't. It eventually took out a sensor and my mechanic found the cause.
The "usual suspects" are the water pump and gaskets but sometimes it's the least suspected that did the crime.
Busted_PT likes this.
Old 05 Jan 2014, 11:05 am
VNT's Avatar
VNT VNT is offline
If it is on the pass side toward the front, could be water pump, bypass hose/connections, upper rad hose/connection, leaky thermostat housing/neck, leaky coolant temp sesnosr where it threads in.
WolfmanG and Busted_PT like this.
VNT
89 Shadow ES 2.5 T2 +20's A555 sold
90 Daytona ES 2.5 T1 A523
90 Datyona Shelby VNT needs work
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
03 PT GT Black 5 sp Stg 1
05 PT GT Silver 5 Spd Conv
Old 05 Jan 2014, 09:37 pm
Well, I looked at it again, and the only reason I saw the drip on the firewall side of the block was because I had the front jacked up. DOH!
When the vehicle is level the drip is closer to the crankshaft center and collects on the oil pan bottom.
And it looks like another picture I found on line where somone suggested that it was the water pump.
I'll let you know.
Old 05 Jan 2014, 09:45 pm
WolfmanG's Avatar
is the car overheating? are you getting any type of colored smoke outta your tailpipe?
-Danny Wolfman G
If you have changed a Turbo you may have the answer hidinginparadise General Turbo Discussions 3 24 Apr 2011 09:15 pm
Looking For An Answer On Code Sassy General Turbo Discussions 6 15 Dec 2008 05:10 pm
NEED CODE ANSWER SHERRI Tech & Performance Forum 7 27 Jun 2004 10:27 pm
