PT SHUTTER AGAIN?
Old 05 Jan 2014, 05:08 pm
Default PT SHUTTER AGAIN?
OK 04 NON TURBO..NEW PLUGS WIRES,,KNOCK SENSOR..NO CODES?
SEEMS LIKE WHEM ITS COLD IT RUNS BETTER BUT AFTER IT WARMS A BIT AT IDLE IN GEAR IT SHUTTERS? U CAN WATCH THE ANTINNA AND IT SHAKES LIKE A RATTLE SNAKE LOL..THE TACH DONT MOVE..JUST THE SHUTTERING?
HAVENT TRY A CODE READER YET?..ANYONE ELSE EVER HAD THIS SYMPTOM?
I"M THINKING VACCUME LEAK? BUT CANT SEEM TO FIND ANY?
Old 05 Jan 2014, 09:41 pm
WolfmanG's Avatar
Default Re: PT SHUTTER AGAIN?
first off, turn off the caps lock, when you type in caps it means you're yelling. 2nd, does it seem like it wants to shut off/stall out? do you have a check engine light on?
-Danny Wolfman G
Old 05 Jan 2014, 09:47 pm
Handy_Cruiser's Avatar
My PT does this if I start it and put it in reverse while holding on the brake. It usually means the engine RPM's are a little too high at idle. And that's why it gets better when the engine warms up and the "cold-idle actuator" (or whatever it's called on a PT) shuts so the car can idle down normally.
What is likely happening is that while the PT is cold, the throttlebody makes the engine idle higher until it warms up. With the engine idling higher, the torque converter tries to set in even though you are holding down the break. So the engine is under a load being held back by the torque converter. And that makes it shutter. I don't know how on a PT, but if you can reduce engine idle while cold, it will likely stop this.
Old 05 Jan 2014, 09:49 pm
Smile Re: PT SHUTTER AGAIN?
I DONT KNOW HOW YOU YELL IN A MESSAGE UNLESS YOUR TYPING SOMETHING BAD. I HAVE TROUBLE SEEING SMALL PRINT. SORRY AND LIKE I SAID NO CODES..
No it dont stall it run out good just the shaking at idle?..weard..
Old 05 Jan 2014, 09:56 pm
WolfmanG's Avatar
i know you weren't yelling, i actually thought maybe you were just excited lol
well, i'm gonna fold on this one. i hope you get it fixed, sorry i couldn't help.
-Danny Wolfman G
Old 05 Jan 2014, 10:37 pm
Ok thanks for trying ..Im stumped.....gonna recheck for vaccum leaks..
Old 06 Jan 2014, 03:26 am
drum; Mine idles at 1200 rpm when cold, then slowly drops down to ~ 700 rpm after 1 or 2 minutes and stays there. Yours should be close to this.
Old 12 Jan 2014, 10:42 pm
idle speeds ok..but still got the shuttering..p0440 p0441 NVLD bad?
woudd this make it shutter? at idle?,..
Old 18 Jan 2014, 10:31 pm
Talking Re: PT SHUTTER AGAIN?
hellloo?
anyone had a bad HVLD? di it cause any idle issues? or just throw the codes?
Old 18 Jan 2014, 10:42 pm
you could always just use a bigger font. This is not all caps, so its not yelling.
