Shifter won't engage gears (most of the time)
Old 05 Jan 2014, 05:34 pm
Default Shifter won't engage gears (most of the time)
In what's got to be "what's going to happen next", I'm driving my 05 PT Cruiser convertible with manual 5 speed home from work. I've gone 2 blocks - leave a red light - 1st, 2nd, 3rd, 4th, then suddenly no 5th. Its just the shifter wobbling all over the range. It will go back into 4th, so that gets me back home. I was wondering the 1st time I stopped if I would have 1st and 2nd again, but it worked. Just no 5th and reverse since its opposite of 5th. Get home and point the car where I won't need to back up to get to work tomorrow (would rather not have to deal with this right now since I'm working 12 hours and its going to be 8 degrees tonight with snow. Now it won't go into any gear and it sloppy all over the range. Sometimes I can find a "groove" where it will go into gear. Any ideas what's up?
I've read an article about getting the shift knob off. I can't believe its not tapped. Don't know if its popped off that it will ever go back. Next question, is there an easy way to get the center console off?
2003 Nissan Altima (Son's)
2011 Smart For2
2005 Chrysler PT Cruiser Convertible (Toad)
2006 Saturn Vue (Daughter's)
1999 Holiday Rambler Motorhome (Retirement home someday!)
Old 05 Jan 2014, 05:37 pm
Default Re: Shifter won't engage gears (most of the time)
Get some booger bushings. 20 some dollar fix.
randyincctx likes this.
Old 05 Jan 2014, 05:38 pm
Likely your shifter bushings need to be replaced. Google "Booger Bushings".
Otherwise the dealer wants to sell you the whole cable.
Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean?
2001 PT Cruiser LE 5 spd, original owner, no mods, MOOG arms with spherical bushing (ride is now a bit harsher vs OEM)
- 109K replaced timing belt/WP/tensioner/idler/crank&cam seals with same 1st gen design. That was a fun day and half!
- 119K Gates water pump failed after only 10K miles. Replaced with Airtex. This time around it was a 7 hour job.
2001 PT Cruiser LE AT 59K miles. Bought used, newest addition to the family
Old 05 Jan 2014, 05:41 pm
randyincctx's Avatar
Cool Re: Shifter won't engage gears (most of the time)
It might also help to check out this thread,among some others.......It'll make things go smoother if you DIY: How to Install Booger Bushings?
Aka:~KILLER~
Old 05 Jan 2014, 05:42 pm
Won't I have to pull the center console out?
2011 Smart For2
Old 05 Jan 2014, 05:43 pm
Another question: if I leave out to work tomorrow, might this condition leave me stranded?
2011 Smart For2
Old 05 Jan 2014, 05:47 pm
Post Re: Shifter won't engage gears (most of the time)
See the link I posted above.....As far as leaving you stranded;It depends on how long it takes you to do it,that's why you should 'study up' first;It'll make it go easier & faster.(less downtime!)
Aka:~KILLER~
Old 05 Jan 2014, 06:09 pm
He means driving as it is. You can cut you some rubber hose to stick on the peg to tighten the hole until you get the bushings.
Old 05 Jan 2014, 06:16 pm
Red face Re: Shifter won't engage gears (most of the time)
OIC...Good point!
Aka:~KILLER~
Old 05 Jan 2014, 07:15 pm
You may have inadvertantly answered my question, but its 26, snowing, and dropping. I mean leaving as is and trying to make it to work (20 miles one way). Seems like its taking a chance. But I really need to go to work.
2011 Smart For2
grinding gears rob342 Tech & Performance Forum 6 17 Aug 2013 04:54 pm
Starter will not engage! Bonekrusher General PT Cruiser Discussions 25 27 Sep 2012 04:50 pm
over rev when changing gears PigFarmer Tech & Performance Forum 5 26 Jan 2012 05:44 pm
skipping gears ProDigit General PT Cruiser Discussions 12 29 Oct 2010 10:09 pm
cams, cam gears?? proxeyed Tech & Performance Forum 14 18 Jan 2005 12:36 pm
