Overflow bottle relocation....
Like Tree9Likes
  • 1 Post By NitroPT
  • 1 Post By 2step
  • 2 Post By wwpptc
  • 1 Post By hotblkpt
  • 1 Post By Busted_PT
  • 3 Post By NitroPT
Old 08 Jan 2014, 01:38 am
hotblkpt's Avatar
Default Overflow bottle relocation....
Has anyone attempted to do this? I'm looking for a alternative to putting it back in the same place and letting the turbo cook it again.... Given the limited space it doesn't look promising. Maybe a better heat shield...hmmmm?
Old 08 Jan 2014, 02:02 am
Default Re: Overflow bottle relocation....
Replace it with a universal aluminum unit. Thermal wrap it.
Not sure why you are having a problem with your reservoir ? Lots of turbo pt without this issue? Including mine. I would like to hear from any member with direct experience to this possible concern.
mityqwik likes this.
Old 08 Jan 2014, 10:53 am
2step's Avatar
I moved my recovery tank from the firewall up next to the radiator. But I could do this because I had room to do it because of other mods that made more space available. My small race battery allowed me to design an intercooler to throttlebody hard pipe that was nearly a straight shot instead of a nest of snakes like the usual one. I bought a tank off ebay that was for a different application but fit the space nicely. And lastly, I changed the radiator filler neck which has the hose fitting on the back side to a non-turbo filler neck which has the hose fitting on the front side.
You can just make out how I ran the new hose along the top of the radiator and then the second "dump" hose hanging straight down to the lower engine compartment.
I have seen recovery tanks made for the hot rod crowd that are 3" round aluminum cylinders about 18" long. Perhaps one of those could be installed on one side or the other of the radiator if there's room. (I can't say. It's been years since I've seen a stock set up.)
hotblkpt likes this.
Old 08 Jan 2014, 04:46 pm
I've only heard of one or two other turbo owners having the same overflow bottle problems you are apparently having. Was your insulation still in place? If it was, then I would replace it by wrapping the bottle with either a single or double layer of an aftermarket heatshield material and put it back in the oem location. It is a logical and convenient spot.
When I replaced my oem NA intake manifold with the composite turbo manifold, the stock NA bottle no longer fit. I used the turbo bottle but I had to custom fabricate a mounting plate to make it function as needed. Because of the proximity to the heat from my Hedman 4-2-1 header I wrapped the bottle in "HUSH-MAT". It protects from heat and is also a noise suppressor. I was only concerned about heat protection. There are numerous other brands of heat mat out there and they all work fine. The HUSH-MAT easily conformed to all the numerous contours of the bottle. Worked great!
How did the 3-D decals work out?
Jerry
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Jerry
mityqwik and WolfmanG like this.
Old 09 Jan 2014, 01:58 am
hotblkpt's Avatar
All the insulation was still in place Jerry....I will look into heat wrap for the new one.. Love the decals, waiting for new paint to install them..thanks!
Jerry
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Jerry
Old 26 Jan 2014, 12:01 pm
hotblkpt's Avatar
Got a new bottle today...wrapped it with insulation and all is well for now.... Thanks Jerry for that tip!!!!
wwpptc likes this.
Old 26 Jan 2014, 01:40 pm
Good tip there Jerry. Hadn't thought of those products. Simply because I have never been around them.
wwpptc likes this.
Old 26 Jan 2014, 06:10 pm
Thanks for the kind words guys!
Like I said, I was worried about the heat coming off of the Hedman. It's worked perfect for MANY years now.
---HEDMAN 4-2-1
[IMG][/IMG]
---HEDMAN 4-2-1
[IMG][/IMG]
Jerry
Old 26 Jan 2014, 06:33 pm
Jerry great pictures and fab work.
You and I were simply living at the wrong time and wrong place....in another time and place.....
Jerry & Lynn's PT Customs ops...made a mistake...... I meant
Lynn & Jerry's PT Customs
WTB ~ Coolant overflow bottle OurPTGT General Turbo Discussions 3 28 Sep 2012 07:54 pm
hood hinge relocation ? bonsylrc Exterior Accessories Forum 9 13 Feb 2012 10:52 am
Coolant overflow woes! Bottle help needed. 03GTCruiser General PT Cruiser Discussions 2 06 Jul 2011 03:09 pm
Plate Relocation thegoldpt General PT Cruiser Discussions 4 06 Jun 2005 05:22 pm
GT emblem relocation. rice_killing_GT Exterior & Interior Styling 13 20 Jul 2003 09:23 pm
