EGR Valve on 2007 PT Cruiser
  #11 (permalink)
Old 15 Jan 2014, 06:20 pm
Default Re: EGR Valve on 2007 PT Cruiser
Oh God, he did it wrong. I sent him out to do it again. LOL I think that's the odometer.
  #12 (permalink)
Old 15 Jan 2014, 06:31 pm
We both have tried. We tried it slow and fast. We tried pausing between and not pausing. We tried pushing it until it dings but not so far as it would turn over and we tried turning it just until the instrument panel lights. I don't know any other way we can try it. There are no codes that pop up. What are we doing wrong?
  #13 (permalink)
Old 15 Jan 2014, 06:39 pm
OMG, that should have been so simple and when I finally got it it was simple. But... it seemed hard while I was trying to make it work. The end result is it says "done"
  #14 (permalink)
Old 15 Jan 2014, 06:55 pm
Okay, so no error codes.
I would schedule new plugs and ignition wires - and get new intake gaskets while you're at it (since rough idle is often due to leaking intake gasket).
Even if that doesn't fix it (and it well may) you can then rule out ignition.
I am REALLY curious how "mechanics" determined a valve job was needed - since I don't hear that they did a compression/leakdown test.
I suspect plug was changed because it was easy - to do all plugs intake manifold has to come off.
The plugs and wires are not hard to do:
Spark Plug Guide
And just to confirm - EGR was on '01 and '02 PTs only - '03 on up has no EGR.
  #15 (permalink)
Old 15 Jan 2014, 07:18 pm
Since I started this thread we've replaced all plugs, upper gaskets, PCV valve, and the wires look good. If you think I should replace the wires anyway, it will take a few days because the local parts store will have to order them. We live out in the boonies. Also looked through the timing belt case plug and saw the belt was spinning when we tried to crank it and my ex-husband said it looked intact (not broken, teeth ok, etc).
When I turn the key it tries to catch and acts like it's not getting gas.
I don't know if they did a compression test but it's suspicious that if they did, why would they immediately jump to that conclusion on a car that idled rough? The whole thing sounds fishy to me but it's my grandson so I'm not going to rock the boat.
  #16 (permalink)
Old 15 Jan 2014, 09:07 pm
You can have wires delivered from online sites - Crane wires are excellent....
The stock wires don't last, so yes, they could be your problem.
  #17 (permalink)
Old 17 Jan 2014, 07:07 am
The wires are ordered but won't arrive until the middle of next week at the earliest. I'll let you know what happens when we install them.
Thank you so much for helping with this.
  #18 (permalink)
Old 06 Feb 2014, 03:03 pm
The first wires were the wrong ones so I had to reorder and wait for them. Now we have them but the weather has gotten bitter cold again. Tomorrow is supposed to get up to 14 so maybe we can get them in then. Once they are installed should we just try to start it?
  #19 (permalink)
Old 06 Feb 2014, 05:31 pm
Why not?
  #20 (permalink)
Old 06 Feb 2014, 10:36 pm
Do we have a smiley for someone biting his tongue?
Jerry
PCV Valve On 2004 PT Cruiser GT RickyRacer Turbo Performance 43 22 May 2015 08:36 am
2004 Cruiser needs a valve job..selling it gabbyblonde Classifieds: For Sale/Trade 9 01 Nov 2013 06:41 pm
PT Cruiser 2002 AC Expansion Valve? larcoelho Tech & Performance Forum 1 23 Aug 2012 05:05 pm
2004 Cruiser EGR valve? scoobydoodle Tech & Performance Forum 4 13 Dec 2011 07:52 pm
Valve job for GT Cruiser? rush123ed Turbo Performance 3 25 Sep 2008 11:12 pm
