2003 limited standard - Needs Help Back Flushing Heater Core
Old 09 Jan 2014, 08:40 pm
Default 2003 limited standard - Needs Help Back Flushing Heater Core
Ok...moving onto the next project. I believe my next move is to back flush the heater core.
Any suggestion on how to back flush the heater core?
Any advice, warnings or suggestions would be appreciated.
Thanks in advance.
Mims
your most needy pt cruiser owner
Old 09 Jan 2014, 08:59 pm
Default Re: 2003 limited standard - Needs Help Back Flushing Heater Core
Thanks in advance.
Mims
Yes. Start your PT and let it run until it reaches normal operating temperature. Now reach back towards the firewall and check the temperature of the "IN" and then the "OUT" hose for the heater core. If they are the same temperature (hot), you don't need to flush the core.
Move on to the next project.
Jerry
Old 09 Jan 2014, 10:25 pm
if you do flush your heater core be careful not to use too much pressure. the cooling system operates between 16 and 19 pounds of pressure. your garden hose may exceed 60 psi.
Old 10 Jan 2014, 01:32 am
i have no heat and it looks like everything is working properly... so believe its the heater core.
I have never back flushed a heater core before ...so thanks for the advice.
Heater core TMas777 Tech & Performance Forum 8 13 Oct 2011 04:31 pm
Heater core in o3 pt bryanschacht General PT Cruiser Discussions 4 02 Feb 2011 06:04 pm
More heater core questions ddash General PT Cruiser Discussions 0 20 Sep 2010 02:23 pm
Heater core and rad replacement ddash General PT Cruiser Discussions 4 14 Sep 2010 06:35 pm
