code P 0304
Old 10 Jan 2014, 09:19 am
j0e j0e is offline
Default code P 0304
Uh oh! Got my first check engine light on the PT.
According to the sticky, I've got a cylinder 4 misfire detected.
Can anyone shed some light on what that could mean?
Could it be an easy fix?
Am I ok to drive until fixed or should I park/tow it?
Old 10 Jan 2014, 09:30 am
Default Re: code P 0304
How is it driving? Rough, shaky idle, skipping at speed? If None of the Above, should be an easy fix.
Causes could be a bad gasket between upper and lower manifold, clogged injector, a small vacuum leak somewhere, a plug or plug wire going bad. Something bad would be internal and a compression check would be needed.
Old 10 Jan 2014, 11:10 am
j0e j0e is offline
It's actually driving fine. I went about 30 miles to work with the light on.
A few days ago I was getting a little hesitation when cold, but nothing since.
It was unusually cold here, car hadn't been driven in four days and battery needed a jump.
Today it ran great though.
I've been "going to" do plugs and wires, just hoping for warm weather.
(New battery too)
Old 11 Jan 2014, 10:46 am
j0e j0e is offline
So once I get this figured out, how do I reset the code?
Old 11 Jan 2014, 10:56 am
Take off negative battery cable, and step on brake (to drain residual charge) - or take it to Advance Auto and have them reset codes with their reader.
You can do that before doing anything and see if code comes back - the code could have been a momentary hiccup.
j0e likes this.
Old 11 Jan 2014, 12:17 pm
j0e j0e is offline
That would be nice if it was just a hiccup!
Old 11 Jan 2014, 10:45 pm
WolfmanG's Avatar
i had one of these codes pop up on my old pt and it turned out to be a burnt exhaust valve.
-Danny Wolfman G
Old 12 Jan 2014, 07:15 am
j0e j0e is offline
Last night I stopped at the store on my way home from work.
When I started the car the check engine light was out!
Old 12 Jan 2014, 01:42 pm
I have a P0302 that comes and goes and car runs fine.
I plan to do plugs and wires when it gets warmer - you should, too...
Old 12 Jan 2014, 09:53 pm
Tucker05's Avatar
I got that too. I had a leak from the valve cover gasket, and so I replaced that, I found oil in the spark plug, with the spark plug still in the block. So i replaced the coil wires and the plugs, cleaned it up as best i can.
But the funny thing is I only got the code after I replaced the valve cover, coil, wires, and the spark plugs. Now I get the p0304 code. lol. I wish i could figure out what it could be. I think I will pull the plug check it and then do an injector cleaner treatment and check the vaccum lines !!
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
04 PT 0300 0302,,0304,,HELP?? drumrooster Tech & Performance Forum 10 03 May 2013 09:35 pm
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
344 code jkinard73 Southeast PT Forum 2 08 Apr 2009 12:54 pm
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
