hole in coolant reserve tank.
  • 1 Post By snapper388
Old 10 Jan 2014, 11:22 am
Default hole in coolant reserve tank.
Help! I have a 2004 pt cruiser w/turbo. Had a little heat before replacing radiator and thrmst. After had zero heat. Being that I am a mechanical midget, yes Ibelieve air could be a problem, and flushing the system. But my real question is... ya ready? I never replaced the coolant researve with the huge hole in it. Could this alone stop me from getting heat? Ps. I had radiator replaced cuz it was cracked.
Old 10 Jan 2014, 12:43 pm
Default Re: hole in coolant reserve tank.
your cooling system is under pressure when hot causing coolant to be pushed into overflow tank. when coolant cools it is pulled back into radiator. if overflow tank has a hole and don't hold coolant air will be pulled in and you will have to add coolant on a regular basis. my guess on the heater not getting warm would be either you have air in the system or a bad thermostat. I only use stant thermostats. I do not use the fail safe thermostats.
pluminator likes this.
Old 10 Jan 2014, 07:09 pm
Same here, I hate failsafe.
I actually buy the stant thermos rated for a few degrees C higher than standard, that way I get good heat on the interior, but still free flowing :-) the 2.4 has a tendency to run a tad cold with standard thermo's
Old 10 Jan 2014, 11:04 pm
The 03 I'm driving has all the heat you want. 175 K Regular T stat. But as stated above, you have to have a working overflow. Or you will still have issues.
Old 11 Jan 2014, 12:08 pm
Well I am told my heater core is blocking circulation
I am layed off and broke. Thinking I could cut lines and by pass. I am desperate, I need my car!
coolant overflow tank 83v65 General PT Cruiser Discussions 5 05 May 2013 02:27 am
coolant reserve boils occasionally. briansmccabe General PT Cruiser Discussions 15 23 Jun 2012 08:46 pm
Coolant overflow tank, hmm.. Kawizx9r General PT Cruiser Discussions 2 16 May 2012 04:44 pm
Hot Fluid Leaked On Foot Drivers Side. Car Fogging Up. Coolant Bubbling in Reserve. 06turbolite Tech & Performance Forum 3 04 Apr 2011 07:54 pm
pin hole leak at turbo's coolant line pppt03turbo General Turbo Discussions 1 21 Aug 2009 12:08 pm
