02 PT Cruiser Starter Problem? Maybe?
Old 10 Jan 2014, 03:15 pm
Default 02 PT Cruiser Starter Problem? Maybe?
I have a 2002 Pt Cruiser (not a turbo). We had a bad cold snap here in Indiana and it would not start. I jumped it with my other car..well, I tried to jump it. Nothing. Car would start to turn over but simply did not have enough juice.
The next day (in 45 below wind chills) I replaced the battery with a brand new one (the old one DID test as "bad"). Still could not quite get there with starting, so I jumped it again. For about 3 hours! Trying occasionally to turn it over...got close, but it did not fire up- barely turned over.
Finally, I tried turning it over one more time and the starter did not even crank- but I saw a small wisp of smoke come up from under the battery tray. now I have power in the car- but if you turn the key you get nothing.
Where do I start??
Old 10 Jan 2014, 03:24 pm
Handy_Cruiser's Avatar
Default Re: 02 PT Cruiser Starter Problem? Maybe?
Read my steps about half way down on this thread. And don't worry about the CAN bus. You ain't got one.
2006 Cruiser No longer taking a jump
Old 10 Jan 2014, 03:43 pm
So if I hotwire the starter and it does not fire, I can assume starter/solenoid is fried?
Old 10 Jan 2014, 06:03 pm
randyincctx's Avatar
Lightbulb Re: 02 PT Cruiser Starter Problem? Maybe?
Have you checked the cables,connections,and grounding points?......What about the relay?
Aka:~KILLER~
Old 10 Jan 2014, 06:22 pm
If you follow the other steps and make sure the battery is good, fully charged and that the ends (both car and battery ends) are in great shape and tight, then hotwiring the starter will often tell you if it is the starter or not.
Remember that sometimes a new battery can be bad.
Tags
starter issue
05' PT cruiser 2.4T .. starter problem? fresh_duude Tech & Performance Forum 3 22 Jul 2013 08:45 am
2002 PT Cruiser starter problems golem43 Tech & Performance Forum 1 27 Nov 2011 02:43 pm
01 PT Cruiser Starter Solenoid Connections Cruisermania Tech & Performance Forum 3 19 Jan 2011 04:41 pm
Viper remote starter problem jdmickies Tech & Performance Forum 3 22 Apr 2010 12:30 am
Starter/Solenoid problem worseforwhere Tech & Performance Forum 5 23 Sep 2008 02:11 pm
