Reversed battery connections- help
  • 1 Post By randyincctx
Old 12 Jan 2014, 05:15 pm
Default Reversed battery connections- help
I am dealing with a 2002 PT Cruiser that had a battery replaced. While replacing the battery the owner hooked positive wire to negative terminal and the negative wire to the positive terminal. It started smoking from under the intake manifold. Now there are major power problems. No dome light, no radio.... Are there any fusible links against the motor under the intake manifold?
Old 12 Jan 2014, 05:28 pm
randyincctx's Avatar
Question Re: Reversed battery connections- help
Have you checked all the fuses?....It sounds like it blew the IOD fuse to me.
Replace the IOD fuse under the hood in the Power distribution center.
It is located near the battery on the driver' side.
Remove the cover and locate the fuse using the label on the top of the cover as your guide.
It is labled IOD/20A.
chuck2112 likes this.
Aka:~KILLER~
Old 12 Jan 2014, 06:14 pm
Vlefaive's Avatar
Default Re: Reversed battery connections- help
Neighbor pooched his battery doing the same thing ( he's an electrician ! ) At any rate, just cost him a new battery....so try that ?
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 12 Jan 2014, 08:28 pm
THANK YOU!!!! My son is a happy camper! Stole the fuse out of the windshield wipers and swapped it out. He called and said that his blinkers are not working and I told him that the WW's and blinkers are most likely on the same fuse. He will replace that tomorrow and we will know for sure. Thanks again!
Door lock reversed blitterbit General PT Cruiser Discussions 2 05 Jul 2013 11:29 am
01 PT Cruiser Starter Solenoid Connections Cruisermania Tech & Performance Forum 3 19 Jan 2011 04:41 pm
ipod connections dwmphd General PT Cruiser Discussions 2 21 Nov 2006 03:00 pm
sub connections Crash Sound and Security Forum 0 10 Jan 2002 04:56 pm
