Here's the issue.
I live in Minnesota and recently it was pretty damn cold (-40 F). So my wife's 2007 PT Cruiser stayed overnight outside in that cold. It had factory battery which she was about to change (Ooops! Too late, fella). So the car didn't start. Then it stayed in cold for another day. We changed the battery for a brand new one. Engine cranks but doesn't start. Cranked it till the new battery died. It was kinda hard to shift the stick to Neutral position. But after pushing and wiggling it I got it in Neutral. Then towed the car to the nearest shop. They say spark plugs have very worn gaps and fuel fouled. Also there is a fuel in oil. So they recommended to replace spark plugs and ignition wires and change oil. I did that and finally started the engine. On the dash it was showing "3" no matter what position I shift on the stick (I tried Park, Rear, Drive). I drove the car a little and stopped it using the manual brake, turned the engine off and... it doesn't start again! Now on the dash it shows "1" (1st gear, I suppose) and shift stick moves but it doesn't do anything, its always "1". When you turn the key into accessories position accessories work (like radio, beeping, air flow) and there is "check engine" light flashing. Turn it to start the engine - everything stops working. Scanner tool doesn't show any error codes. Remote keys doesn't work for some reason too. So here's the question: What the hell happened to this car and how to fix it??? ![]() Thanks in advance! |
I have MaxiScan MS300 CAN OBDII scan tool (costs around 20 bucks). Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive. Plug it into port, turned the ignition into accessories position and then its reading the computer, but returns no error codes. And I remember I was using same tool on the same car and it was working about a year ago, it was giving error codes about emission system. But now it doesn't show any errors
How do you check for codes via the OBD system?
You need to turn the key from off to run 3x, like on-off-on-off-on.
if you do it right,it'll either tell you codes in the odometer area,or it'll simply say "done".
![]() Aka:~KILLER~ ![]() |
That trick doesn't work because every time I turn the key into the Run position everything stops working (radio, air conditioner, instrumental panel)
OK, that was a quick fix. Just needed to check and reconnect transmission cable (rope or whatever). The tow truck driver was pushing too hard on the shift knob trying to get it into N position, also he broke the ignition, so the key stucks there sometimes. What a dumbass!
![]() Quote:
Thread Tools | |
Display Modes | |
pt cruiser automatic transmission topic | Cyclone35 | General PT Cruiser Discussions | 44 | 07 Feb 2017 06:06 pm |
Automatic Transmission won't shift into 1st gear when cold | Harry2011 | Tech & Performance Forum | 6 | 21 May 2012 01:04 pm |
automatic transmission (2002 pt cruiser) | javolier | Tech & Performance Forum | 15 | 20 Oct 2011 07:25 am |
Did Transmission Fluid Change...Now Its Stuck On 1st Gear | sirminder | Tech & Performance Forum | 25 | 28 Jun 2011 02:42 pm |
using second gear with automatic transmission? | gfx | Tech & Performance Forum | 2 | 18 Jul 2004 02:24 pm |
