Air bag module
Old 13 Jan 2014, 03:26 pm
Default Air bag module
Daughter has a 2004 PT . battery went dead , airbag light went on and stayed on after new battery was out in . now the airbag light won't go off. she had it scanned (?) and apparently the module needs replacing .
Anyone know where the module is, can I replace it or is it a dealer only repair and what's a module cost ?
Thanks
Old 15 Jan 2014, 07:36 am
Default Re: Air bag module
Any help
Old 15 Jan 2014, 08:40 am
Ray_Dockrey's Avatar
Have you tried unhooking the battery and letting the system reset. This fixes a lot of issues.
I think everything is contained within the airbag itself. Also, it has a passenger side airbag which has seat sensors to know when someone is sitting in it. Any of that can cause the light to come on. Here is one thread I found doing a Google search.
Air bag light
Airbag Seat Sensor???
Old 15 Jan 2014, 05:41 pm
Thanks,, yes unhooked the battery , didn't reset then she had it scanned and it has a short and it's not resettable ...
Old 15 Jan 2014, 06:06 pm
The airbag controller module is attached to the floor pan under the floor center console, just behind the shifter assembly.
Jerry
Old 15 Jan 2014, 07:43 pm
Thanks , and is that something I can I change ?
Old 15 Jan 2014, 08:29 pm
From PT Cruiser shop manual:
ORC (occupant restraint controller) is airbag module
"REMOVAL
Disconnect and isolate the battery negative
cable.
Wait two minutes for the system reserve capacitor to discharge before servicing any airbag components.
Remove the center console
Remove ORC module mounting nuts and ground eyelet, then remove module.
Disconnect ORC 23-way connector.
Remove ORC from vehicle.
INSTALLATION
Connect ORC connector and ensure that the connector and all locking tabs are engaged.
CAUTION: USE SUPPLIED NUTS ONLY
(Position ORC (arrow pointing forward) in the console floor bracket, replace ground eyelet, and attach the nuts and tighten to 9.6 to 14 Nm (85 to 125 in. lbs.) torque.
NOTE: Place the ground eyelet over the front (towards the front of the vehicle) weld stud when reattaching the ORC.
Install center console assembly
WARNING: DO NOT CONNECT BATTERY NEGATIVE
CABLE YET (Refer to ELECTRICAL/RESTRAINTS
- DIAGNOSIS AND TESTING - AIRBAG SYSTEM)
Close hood.
Verify vehicle and system operation"
"With the battery negative remote cable disconnected, connect the DRB IIIt scan tool to the Data Link connector.
Turn the ignition key to the ON position. Exit vehicle with the scan tool.
After checking that no one is inside the vehicle, connect the battery negative remote terminal.
Read and record the ACTIVE Diagnostic Trouble Code (DTC) data.
Read and record any STORED DTC’s.
Refer to the proper Body Diagnostic Procedures manual if any DTC’s are found.
If the airbag warning lamp either fails to light, or goes ON and stays ON, there is a system malfunction.
To test the airbag warning lamp (bulb) operation in the cluster, refer to Electrical, Instrument Cluster, Diagnosis and Testing - Instrument Cluster.
Refer to the proper Body Diagnostic Procedures manual for any other system problems."
Old 15 Jan 2014, 08:34 pm
The repair sounds good, not sure about the testing ...thanks for the info
RKE Module oicurok2 Classifieds: Want To Buy 3 05 Jan 2014 07:21 pm
Where is the SKIM module? BarbMc Tech & Performance Forum 9 09 Jul 2013 01:04 am
PCM/ECU Module Morkeste Tech & Performance Forum 43 04 Aug 2011 10:23 am
Fan Module mpw3ed Tech & Performance Forum 1 14 Mar 2011 06:29 pm
Tri_Phase Module Art Rigby Tech & Performance Forum 5 17 Nov 2003 10:25 am
