Radiator Fan wiring harness
Old 14 Jan 2014, 09:46 pm
Default Radiator Fan wiring harness
I went to replace my radiator fan on my PT Cruiser this past weekend and found that someone who had previously worked on my PT had cut out the wiring harness and had permanently wired the fan with wire connectors. My replacement fan has a harness and I don't want to cut it off and void any warranty. Do you know the size or model number of the male harness that I would use to re-wire and connect to the fan? Thanks!
Old 01 Feb 2015, 02:44 am
Default Re: Radiator Fan wiring harness
Is this the type of connector you are looking for?
ACDelco PT2188 Radiator Fan Switch Connector | eBay
Old 01 Feb 2015, 04:35 pm
sanatanadharma's Avatar
Is there an auto salvage yard you can visit?
If you have your replacement radiator in hand, compare the connector to those in these pictures.
First picture from this site
The following is from Advance Auto; The three-wire radiator connector may be the same as the camshaft position connector.
CREWZIN post with picture of connector
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Cut wiring harness - UGH!! binptguy Tech & Performance Forum 4 15 Jul 2012 04:06 pm
Wiring Harness mnso123 Classifieds: Want To Buy 0 07 Jul 2012 02:09 pm
wiring harness BeagleDad Classifieds: Want To Buy 0 09 Dec 2011 02:05 pm
wiring harness? PTcruzer02 General Turbo Discussions 1 26 Jul 2009 06:08 pm
