Engine shut off while driving. No codes
  • 1 Post By VNT
Old 18 Jan 2014, 01:31 pm
Smile Engine shut off while driving. No codes
2002 cruiser 97,000 miles. New timing belt, new head gasket work. Engine quits but still cranks over. Shut off is sudden with no pre existing conditions.
Re-starts after cooling down. Driving distance before next failure gets shorter each time. No engine codes at all. Is there a ignition module that is going bad or coil? Can you offer the best course to pursue? Thanks, Steve
Old 18 Jan 2014, 02:10 pm
Default Re: Engine shut off while driving. No codes
Did you run out of gas?
Old 18 Jan 2014, 04:16 pm
Your kidding right?
Old 19 Jan 2014, 05:06 pm
LOL!!!!
Its a fair question
Originally Posted by Twoscoops2 View Post
Your kidding right?
Old 19 Jan 2014, 05:55 pm
VNT's Avatar
VNT VNT is offline
There is a ignition module in the steering column, sometimes they fail(open circuit and kill power to pcm) when you pull over and you restart the car it will fire right over. They are about 50$ at the dealer(get a mopar one) and take about an hour to change you need some torx bits and 1/4 drive.
Other thing that can cause intermitant stalling is the cam sensor, sometimes will leave a code sometimes not.
Lastly I had a 05 PT GT, I had to change the PCM, co-piloted it and was loosing bus communications hence no code, most likely for that situation is issue with the instrument cluster( when car sometimes died cluster would act up, gauges go funky etc) or PCM. I guessed cluster and then PCM so I lost!
garkeller likes this.
VNT
89 Shadow ES 2.5 T2 +20's A555 sold
90 Daytona ES 2.5 T1 A523
90 Datyona Shelby VNT needs work
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
03 PT GT Black 5 sp Stg 1
05 PT GT Silver 5 Spd Conv
Old 19 Jan 2014, 09:08 pm
randyincctx's Avatar
Lightbulb Re: Engine shut off while driving. No codes
Similar issue has been reported due to ground wire in the steering column,you can test this by moving the steering column up & down,and see if it changes the result......This usually only affects the radio & display though.
Aka:~KILLER~
Old 21 Jan 2014, 07:24 pm
Thanks for the input. When it dies it still cranks over but won't start till it gets cold. Then starts right up till the next shut off.
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
Car shut off, restarted, no codes?? Samson Tech & Performance Forum 5 21 Mar 2012 04:30 pm
Pt shut off while driving! ego957 Tech & Performance Forum 11 17 Jun 2009 01:42 pm
Engine Shut Off, Will Not Restart Stevearino Tech & Performance Forum 37 18 Oct 2007 11:55 am
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
