Front Turn Signal Lights Turn On and Off When Applying Brake?
Old 19 Jan 2014, 07:26 am
Danny7627's Avatar
Default Front Turn Signal Lights Turn On and Off When Applying Brake?
A few days ago, I was pulling in the parking lot of a 7-11 facing the window and I noticed that my front signal indicators both lit up when I applied the brake (07 PT Cruiser)
I went home and pulled, reset and visually inspected the bulbs and connectors including the license plate bulb and could not find anything wrong. All worked ok.
The problem as of yesterday was intermittent. It had stopped happening for a day or two and then yesterday while I was stopped at a light I saw it was occurring again from the reflection from the car ahead of me. Maybe the turn signal switch?
I'm off to work this morning. Hopefully, this evening I will be able to figure it out when I read the responses.
Thanks
Danny
2008 Convertible Turbo -lite
2007 Touring N/A Boneyard
Old 19 Jan 2014, 07:47 am
garkeller's Avatar
Default Re: Front Turn Signal Lights Turn On and Off When Applying Brake?
OMG...I HATE electrical problems
Hope it's an easy fix---I've got a weird one too in that only my front turn signals flash with my hazards, nothing on the rear---I've been ignoring it so far as everything else is okay
Old 19 Jan 2014, 07:15 pm
Danny7627's Avatar
Anyone?
Old 19 Jan 2014, 07:28 pm
randyincctx's Avatar
Lightbulb Re: Front Turn Signal Lights Turn On and Off When Applying Brake?
Could be the MFS,but you should check the wiring & connector the plugs into the MFS,see if any of the wire insulation looks burnt or 'melty' there.
Aka:~KILLER~
Old 19 Jan 2014, 08:23 pm
Danny7627's Avatar
Thanks Randy, I have run some leds here and there but was ever so careful with the wiring. Tomorrow, I will check all the connections and wires again. Everything is functioning properly otherwise.
Maybe its an option to annoy the driver ahead of you in traffic?...lol
Old 19 Jan 2014, 08:57 pm
Wink Re: Front Turn Signal Lights Turn On and Off When Applying Brake?
In the meantime,if santanadharma comes along he'll probably have alot of good info & pics on these kinds of issues.....
Aka:~KILLER~
Old 19 Jan 2014, 11:26 pm
sanatanadharma's Avatar
In the meantime,if santanadharma comes along...
He will have to tell you Danny, I have no knowledge of the canbus second-gen electrical system. I would like to have the electrical schematics, but without which I am in ignorance; intermittently, and that is the worst kind.
Do the rear turn signal indicators also light up when the brakes are applied?
Perhaps a short in the wiring where brake light and rear turn light systems are adjacent. If so, the flashers should also flash the brake light bulb. I doubt that the MFS is involved.
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Old 20 Jan 2014, 06:13 am
Danny; LED's will sometimes confuse the TIPM if they don't draw enough current. You may have to go back to the original bulbs and reset the electrical system by disconnecting the neg battery terminal and stepping on the brake pedal a few times.
Old 20 Jan 2014, 06:38 am
Handy_Cruiser's Avatar
First, switch you hazard lights on and off several times. Sometimes that's the culprit. Next, if you still have incandescent tail/brake light bulbs, check those. Sometimes the elements inside a double element bulb with touch. This can cause a connection between the brake light circuit and the marker light circuit. Thus, the front markers can come on with the breaks. I imagine the same could happen with LED double element bulbs if the wires on the base are touching.
Old 20 Jan 2014, 07:02 am
Danny7627's Avatar
I appreciate all of the responses.
A few weeks ago I had one brake bulb burn out so I replaced both with Pilot L.E.D. brake 3157 bulbs. Nice and bright.
I was thinking that these might be the culprit.
I will take them out today and replace with original (new3157's) and see what happens. Hopefully, this works.
Also Handy, I will try what you suggested first to see if it's the remedy before I replace the LED bulbs.
Thanks Again!
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
Right front turn signal not working rctjroy Tech & Performance Forum 3 15 Sep 2012 04:26 pm
2006 - Turn signal/driving lights Tarnishedknight Tech & Performance Forum 10 02 Sep 2010 08:23 am
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
Help removing front turn signal reflector. GT_Firebreather Exterior Accessories Forum 7 28 Jul 2003 02:14 pm
