2001 PT Cruiser - Charging System Problem
Old 20 Jan 2014, 01:38 pm
tdf tdf is offline
Default 2001 PT Cruiser - Charging System Problem
Would someone be kind enough to post the wiring diagram of the 2001 PT Cruiser charging system?
I have installed a newly rebuilt engine and after hooking up what I believe to be all the wiring harness the charging voltage 14.7 volts is not getting to the battery. The alternator tested good at 14.7 volts of output.
I must have missed something or there is a fuse or fused wire that has gone bad.
Any suggestions for where to look or test for continuity? Help would be appreciated.
Tom
Old 20 Jan 2014, 02:51 pm
sanatanadharma's Avatar
Default Re: 2001 PT Cruiser - Charging System Problem
From 2002 Mitchell Repair Guide
sanatanadharma when you are no longer posting in stealth mode and make the availability for PMs then welcome , join and participate on this forum as a supporting member. Until then your responses in most threads will be temporarily removed.
Old 20 Jan 2014, 02:55 pm
tdf tdf is offline
Thank you very much "sanatanadharma". I appreciate you taking your time to post this for me.
Tom
Old 21 Jan 2014, 05:27 am
TDF; note the fusible link [green wire]. Easy test if you can get to the large lug/stud on the alternator. But it could also be the field circuit.
Charging System Help RMoore Tech & Performance Forum 21 27 Aug 2012 09:28 pm
Charging system robmet55 Tech & Performance Forum 4 22 Jun 2012 11:18 pm
Charging system battery voltage DJmart Tech & Performance Forum 19 14 Sep 2011 11:26 pm
Charging system issues Murdered Tech & Performance Forum 1 12 Feb 2011 07:37 pm
Looking for charging system mods oldcoach General PT Cruiser Discussions 0 27 Oct 2007 05:16 am
