engine mounts
Like Tree9Likes
Old 20 Jan 2014, 06:05 pm
Default engine mounts
I am wondering if anyone has bought the 2 engine mounts that are on the timing belt side, upper and lower, from amazon and then switched over to 2 mounts from Chrysler, if there is any noticeable difference in the amount of vibration.
I bought 2 from amazon, and right away the car was vibrating like crazy, I aligned the engine according to specs, and the vibration did seem to ease a BIT, but after 4 months, I am thinking of spending some more money on a set from Chrysler, mind you, not knowing if there is any difference.
Any thoughts out there?
tnx...Rotty
Old 20 Jan 2014, 06:18 pm
Default Re: engine mounts
The durometer of the rubber from the MOPAR mounts and most all aftermarket mounts is the pretty much universally the same.
Old 20 Jan 2014, 07:03 pm
There is a difference in an auto and manual lower mount. Could this be your issue?
Old 20 Jan 2014, 08:31 pm
How can you tell the difference between the 2 mounts?
Old 20 Jan 2014, 08:37 pm
further to my last reply, I went on the web and none of the jobber parts sites ask if you have an auto or standard.
I have an auto, a 2001, and just took for granted that the 2 parts were ok as they fitted.
Maybe tomorrow, I'll call Chrysler Parts and ask them, that would answer my problem if that were the case. My PT idled smoothly until I replace the mounts.
Old 20 Jan 2014, 08:38 pm
The part number for one and they look different. Somewhere on here is a picture when someone else was having issues.
Old 20 Jan 2014, 08:43 pm
I just looked at Rock auto's cat. and they show an upper mount for automatics.
I could see were a small size difference could make a difference. Thanks for the advice, when I get it sorted out, I'll post it so others will know.
Busted_PT likes this.
Old 20 Jan 2014, 08:50 pm
Thanks Busted_PT,
I found the link,
Anchor Upper & Lower Motor Mounts ?
Now the fun begins, trying to sort it all out.
Old 20 Jan 2014, 09:09 pm
Thanks Busted_PT,
I found the link,
First I heard of the upper being different. If it actually is. But will be watching for the answer.
Old 20 Jan 2014, 09:19 pm
soonercruiser's Avatar
Lightbulb Re: engine mounts
I will get the timing belt and water pump replaced in the 2005 Dream Cruiser this coming month before I make any more long trips. (93K)
But, I do have one little irritating mechanical problem, that I think might be a motor mount.
When I even press on the accelerator moderately, I get a little clink in the right front end.
I thought that it might be a CV joint or something.
Today I noticed that it does this same thing (a little less pronounced) when I am sitting still, and put it in gear.
Think this might be a motor mount?????
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Engine mounts denboy General PT Cruiser Discussions 1 19 Mar 2013 08:33 pm
Engine Mounts!? kcpope Tech & Performance Forum 11 24 Dec 2012 02:29 pm
Engine Mounts bheffner PT Cruiser Convertible Forum 2 06 Sep 2012 10:37 am
engine mounts lt4supr Turbo Performance 25 05 Oct 2011 01:19 pm
engine mounts lt4supr General PT Cruiser Discussions 11 04 Jun 2008 07:56 am
