Weird code P050B
Old 20 Jan 2014, 07:57 pm
Default Weird code P050B
Has anybody ever encountered this code before? Took the car to the shop today to have them help me diagnose this, and they'd never seen this particular code before. Doing my own research, it refers to cold start ignition performance, but we're at a loss on how to troubleshoot. The car has been idling unusually low lately, around 600-650rpms cold. When applying the clutch to stop, the rpms will drop quickly and sometimes the engine might stumble a bit. I had the throttle body taken off and cleaned, including the IAC valve. The car now seems to idle a bit smoother, and the code hasn't come back... waiting to see what happens tomorrow morning when I start it. Does anybody have any suggestions?
2006 Base, 5-speed, 146k miles.
Old 20 Jan 2014, 08:27 pm
randyincctx's Avatar
Lightbulb Re: Weird code P050B
Looks like you may only be the 2nd,or 3rd person to report this code.
A similar issue (and code) was mentioned in a thread last year,and for one member it turned out to be a broken wire leading up to the MAP sensor,and bad wires on the throttle position sensor.
Hesitation problem
Aka:~KILLER~
Old 21 Jan 2014, 10:51 am
Default Re: Weird code P050B
Thank you! I reread everything from that thread, the problem was similar yet different then mine. After cleaning the throttle body and idle air valve, at -3 degrees F this morning, the car started and came to life a lot smoother then it has in several years now. I'm hoping that is what may have been triggering the code.
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
?? WEIRD ?? mdskinner731 Tech & Performance Forum 7 28 Mar 2012 05:22 pm
Weird.... Busa_Powered General PT Cruiser Discussions 12 23 Jun 2011 10:05 pm
Weird Noise ptlovr Tech & Performance Forum 7 05 Jul 2006 07:14 am
This is just too weird turbomangt Turbo Wheels/Suspension/Handling 3 02 May 2004 11:04 pm
