vss had wire detached...no speedometer
Old 22 Jan 2014, 12:01 pm
shelbyzman's Avatar
Default vss had wire detached...no speedometer
I got the code... P501 when my speedometer stopped working. So I was going to change it and noticed that on wire to the connector wasn't even attached. I could see the part of the wire that detached to reconnect them. Even if I had...I do not know how I would since there is no room to work with. Do they sell the connector with the cable/wire....and where does the other end attach?
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 22 Jan 2014, 12:19 pm
Default Re: vss had wire detached...no speedometer
If this is what your referring to, I can see where there's not lot of room to work.
Old 22 Jan 2014, 12:39 pm
shelbyzman's Avatar
Mine is a 5-speed....so its even harder to get to. Its in a different place.
P0750 and a little red wire, and a blue wire? gwairbrush General PT Cruiser Discussions 1 20 Jun 2013 06:39 am
A hose detached from the top of my engine... NicoleW Tech & Performance Forum 18 02 Dec 2012 10:17 pm
Speedometer bennyhill007 General Turbo Discussions 6 26 Oct 2012 10:05 am
Speedometer rockhillcruiser General PT Cruiser Discussions 2 17 Sep 2011 09:17 am
Speedometer is off by 2 mph. Knucklehead Tech & Performance Forum 10 31 Aug 2004 02:46 am
