2006 base model wont start
  • 1 Post By CREWZIN
Old 25 Jan 2014, 10:48 pm
Default 2006 base model wont start
I'm having Trouble Car Not Starting Replaced The Battery And Terminals Its Sounds Like It's Trying To Turn OverBut ThenWill SomeTimesMake A Grinding Noise Or Will Start For A Sec Then Die Again Has ASlight Smell Of Gas After A Few Attempts It's Been ReallyCold Here AndThat's When The Issues Started Is At A Cold Snap Of nagative 30 Or So Then Worked For A Week got Cold Again Now ItS Back To Not Starting Not Sure What To Do Any Help Would Be swell
Old 26 Jan 2014, 10:40 am
Default Re: 2006 base model wont start
Darn, I bet it's hard to type that way with capital letters at each word and no punctuation, makes it darn hard to read.
Anyway, to your problem. Have you changed the ignition parts (Plugs and wires)? Have you checked the OTHER battery terminals and all the grounds for corrosion and tightness? If you jump start it from a good battery source, does it start right up and keep running? We just need more information on what you did before we can suggest things that might help.
Second, if it gets THAT cold and you don't have a garage, you might think about buying and using one of the things that keep the oil and battery warm while it sits outside in that horrible weather.
Third. that new battery you put in. Was it laying on the shelf of an autostore when you bought it (for how long)? Was the charging system of you car checked by that store before you bought the battery so you know it's charging up OK when you use the car?
mityqwik likes this.
Old 26 Jan 2014, 11:19 am
Doing This From My Phone So Types Everything Weird But Have Not Checked Plugs Or Wires Yet But Battery Was Sitting On A Shelf Not Sure How Long Tho But Old Battery Was The Only Thing I Could Bring In Since Car Wasnt Starting But Checked Terminals Everything Was Tightened Up And When I Try And Jump The Car It Only Starts For The Sec And Dies
Old 26 Jan 2014, 11:23 am
Well, since it's that cold, you could have a problem with the gas freezing up. Not necessarily the gas, but any water in the gas. Let it sit and you get a few drops to start the car and the frozen section stops the gas from getting through to the injectors and the car stalls. You might not have a problem except that you need to let the weather get warm. Throw in a couple cans of de-icer into the fuel tank to get rid of the water and you'll be good to go.
Just a thought. Had that problem in an old Dodge I had. Block of ice in the fuel filter back in Maryland.
Ahhhhh. Another reason to add to my list why I moved to Florida. Calling for 76 degrees this afternoon.
Old 26 Jan 2014, 01:28 pm
randyincctx's Avatar
Lightbulb Re: 2006 base model wont start
Try some shots of 'Starter Fluid' in the TB/intake...Be sure to follow the instructions on the can.
Depending,you may actually need to clean the TB also.
Aka:~KILLER~
Old 26 Jan 2014, 02:18 pm
[QUOTE=CREWZIN;509023]Darn, I bet it's hard to type that way with capital letters at each word and no punctuation, makes it darn hard to read.
I was thinking the same thing, but didnt say anything or I might get a nasty note from Crewzin
Old 26 Jan 2014, 02:23 pm
[QUOTE=Busa_Powered;509059]
You'll notice Busa that I also went on to answer the persons question as best I could and just didn't leave it as a sarcastic answer and go away which would add nothing to the thread.....as you usually do.
Old 26 Jan 2014, 04:15 pm
It started Now EvenInThis Negative 7 Weather HadTo Us A Blow Dryer To WarmIt Up A Little Been Running Now For About 15 Min Or So Gives A Little Sudder Every Few Min Or So But Going To Put Some Deicer In When I Make It To The Gas Station Hope It Will Start Again After I Fill Up
But Thanks For The Help Will Post Again If Any Futher Issues Happen
towing with 2006 base model turtle General PT Cruiser Discussions 7 03 Jul 2013 10:11 pm
Removing - Replacing Radiator Fan 2006 PT Cruiser Base Model CashReject Tech & Performance Forum 4 31 Oct 2011 12:57 pm
2004 base model Crusier won't start rjr Tech & Performance Forum 7 24 Oct 2010 02:15 pm
2006 Base Model Window Switch problem bobgengeskahn Interior Accessories Forum 4 04 Jun 2010 06:57 pm
No start - 2001 base model bobdole369 Tech & Performance Forum 8 05 Mar 2009 08:58 pm
