2.2 crd rough idle
Like Tree3Likes
  • 1 Post By pt06
  • 1 Post By Ameranth
  • 1 Post By pt06
Old 26 Jan 2014, 03:10 am
Default 2.2 crd rough idle
Hi guys
Hope someone can help me. I have a 2003 2.2crd. The car started idling rough about 2 days ago, but the thing is it only sometimes idles like this. It starts fine, no loss in power. I have read a couple of suggestions saign it could be the idle valve (witch it doesn't have), the pcv valve(can't seem to find it or the egr valve. Any suggestions? O yes and there is only 1 error code 1130 but thats something about a efi sensor......
2003 2.2 crd
Old 26 Jan 2014, 10:23 am
Default Re: 2.2 crd rough idle
Welcome to the forum.
The forum is based in the U.S.A. and they don't have the Diesel PT here (some wish they did) so if you problem with rough idle is diesel related, hopefully someone from the forum from overseas will come along and try and help you out.
Meanwhile, what have you done to try and solve the rough idle? Injector cleaner, new plugs and plug wires.
I do know the Diesel has a separate plug for heating things up, something called a "glow plug" and maybe that could be causing problems.
HowStuffWorks "Diesel Fuel Injection"
Old 26 Jan 2014, 12:27 pm
I had a diesel many years ago...
Diesels are very "picky" about their fuel - any moisture in the fuel causes havoc -- perhaps try a fuel additive for moisture?
Old 27 Jan 2014, 12:47 am
Ameranth; I'd try the fuel additive first, as stated by Quick. Use a diesel additive only.
Check for engine codes. [example P 04xx codes are related to the egr valve]. And the engine has a computer and sensors. This is not your father's Oldsmobile diesel. Thankfully!
Old 27 Jan 2014, 10:45 am
The diesel is a decent engine, it's Mercedes' C220 CDI. Lots of low end torque
I did take of the egr valve yesterday and cleaned it. Sort of worked, now it only idles rough when it's cold (first start in the mornings and sometimes when I switch on the air-con. I did change the glow plugs and refurbished the injectors and diesel pump about 8 months ago. As for the error codes it only gives me a code regarding the HO2 sensor in the exhaust, but that been there for awhile now.
I'll try the additive and see if that hopefully works. Sometimes I think the newer diesels has to many sensors.....
Thanks for the help so far guys, it's appreciated
2003 2.2 crd
Old 28 Jan 2014, 04:21 am
Ameranth; Mercedes diesels have a good reputation. Maybe by fixing the 02 code, the idle will smooth out? I'm not a diesel guy. Try a mercedes site?
Old 03 Feb 2014, 01:15 am
Just to let you know what the problem was, if ever anybody else has this problem. The culprit in my case was a sticky fuel pressure regulator. Car is purring like a little kitten.
FastFerret likes this.
2003 2.2 crd
Old 03 Feb 2014, 05:31 am
Amer; thanks for the update. I'm happy for ya!
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
Rough idle gvc2000 Tech & Performance Forum 3 26 Jun 2012 12:06 am
rough idle deafy06 Tech & Performance Forum 4 17 Jan 2012 12:00 am
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
