I'm in the process of changing the timing belt and water pump on my 2.4 na PT. When I pulled the timing cover this is what I found (see pics). It appears most of the build up is in the lower half of the cover,,,,from the tensioner down. I pulled the crank gear but the seal doesn't appear to be torn. Any other ideas,,,or is it probably from the crank.
Thanks |
It could actually be from just the crank seal,and just getting slung all over the place by the belt,tensioner pulley,cams,etc.......Seems more concentrated around the crank seal.....If your doing the TB & WP,your already most of the way there,might as well change it also,given it's probably the original,and has 180k on it.....Lots of good info here:
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
![]() Aka:~KILLER~ ![]() |
I think that the cam and valve cover gaskets should also be changed. They wont show tearing, they just ware out.
![]() Quote:
Had a cup of hot tea and pondered how I was going to get it clean before assembly... Hot Tea- boiled water- Boiled up two pots of water and slowly poured it down the timimg end of the engine and OMG perfectly clean ![]() and I replaced them..
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
Thread Tools | |
Display Modes | |
Oil leak on timing belt | tpdeehan | Tech & Performance Forum | 5 | 23 Feb 2016 05:57 pm |
Radiator Leak + timing belt kit | DenisMcG | Tech & Performance Forum | 3 | 25 Oct 2012 05:14 pm |
oil leak valve cover? | jamestown478 | Tech & Performance Forum | 7 | 11 Jan 2011 08:38 am |
Coolant Leak - Timing Belt | hdave | Tech & Performance Forum | 2 | 16 Dec 2009 05:58 pm |
