Camshaft & Knock Sensor Codes- Again!
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By JimtheIV
Old 26 Jan 2014, 09:09 pm
Angry Camshaft & Knock Sensor Codes- Again!
Hello- My wife has a 2005 Base model, automatic transmission. It only has 58K miles on it but one of the engine mounts snapped back in 2011 and we've had issues ever since. Approx 3 months ago the current problem started. It is an intermittent check engine light that comes with a rough idle, problems accelerating (especially right after an upshift) and codes for knock sensor & camshaft sensor. I replaced the two sensors and everything was fine for about 2 months, then it started up again. Anyone seen this before? I'm no master-tech by any means but I'm not afraid to get my hands dirty. I'm hoping it's something I can do at home but I'd at least like to point my guy in the right direction if I can't. Thanks for any advice you can give!
Jim in Albany, NY
Old 26 Jan 2014, 09:21 pm
Default Re: Camshaft & Knock Sensor Codes- Again!
Jim, welcome to the forum.
Yes, seen it a thousand times before. My guess is that you bought the sensors at an auto store. These sensors may look the same but aren't made the same. They don't last ans the cruiser doesn't like them. Buy some new sensors at the Chrysler/Dodge dealer. They may cost a bit more but once you change them, you shouldn't have to deal with your problem again.
WolfmanG likes this.
Old 26 Jan 2014, 10:20 pm
Do as Crewzin said but also get tea target magnet ( behind camshaft sensor) just to be sure. Its like 16 bucks at the dealership
Old 03 Feb 2014, 05:20 am
any luck?
Old 06 May 2014, 08:49 am
Thank you everyone for the advice. I did end up taking it in to the dealership and paying for OEM sensors to be put in. (Probably could have done the knock sensor myself but since I couldn't really get at the cam shaft sensor in my driveway I decided to let them do the whole job!)
Total bill was around $300 but everything seems to be just fine now.
Thanks again!
CrankShaft Sensor/CamShaft Sensor Questions PTMomma Tech & Performance Forum 8 12 Aug 2014 01:43 pm
Crankcase sensor /Camshaft sensor PigFarmer Tech & Performance Forum 21 20 Mar 2012 07:01 pm
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
knock sensor cajuncody Tech & Performance Forum 0 04 Sep 2007 07:46 pm
S-1 PCM/ knock sensor? tezz Stage Turbo Kits 1 09 Oct 2004 12:29 am
