can a 01 pt clutch be bled
Old 27 Jan 2014, 08:17 pm
Default can a 01 pt clutch be bled
just had the clutch and gearbox replaced on my 01 pt cruiser base model. the clutch pedal is very low and ocassionally I have to pump the pedal to be able to engage the gears, the garage that did the work said I need a new master cylinder as these systems cannot be bled in the usual ways and the new one is modular and come pre bled, is this correct or is there a way to bleed the system?
Old 30 Jan 2014, 07:45 pm
UptownSport's Avatar
Default Re: can a 01 pt clutch be bled
The manual says to 'pump the pedal ten times' to bleed the system.
There is a clutch adjustment under the dash- at the risk of being Mr. Obvious, near the clutch pedal.
Old 31 Jan 2014, 07:24 am
thanks, how do I know if there is air still in the system, and pointing out the obvious sometimes helps, its so obvious I didn't think of it, thank you
Old 31 Jan 2014, 01:09 pm
I suppose it's like air in brake lines, pedal moves, but is only compressing air.
In other terms, pressing the pedal is (at least partially) ineffectual.
Which clutch set JMWEBB General Turbo Discussions 1 10 Jan 2014 02:24 pm
Clutch ptbruiser2009 Turbo Performance 5 04 Oct 2009 09:23 pm
03/06 clutch neon95 General PT Cruiser Discussions 2 28 Jun 2009 09:37 pm
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
