PO700,PO720 Trouble codes
Old 27 Jan 2014, 09:21 pm
Flowrider's Avatar
Default PO700,PO720 Trouble codes
Recently on my '01 PT I've had shifting problems and erratic behavior on the speedometer gauge. Plus the car would get stuck in 2nd gear. I know that usually means a Limp mode but I replaced the output speed sensor and still the problem remains. I did clean the contacts on the wiring harness for the TCM as well as the contacts on the TCM itself, and that helped for 3 weeks.
Now it's starting again. Is there a way for testing the TCM for proper resistance in Ohms before spending $200+ on a reman unit?
Say No To Stock! Cruisers should be customized!
Trouble Codes Help txh976 Tech & Performance Forum 12 25 Feb 2014 02:55 am
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
Help with trouble codes? darren70 General PT Cruiser Discussions 1 29 Jul 2011 09:45 pm
Whats the difference between key trouble codes vs odometer ones? sknight88 Tech & Performance Forum 10 22 Jun 2008 04:56 pm
