Ultra Gauge Mounting tip
Old 28 Jan 2014, 02:07 am
needmoretoys's Avatar
Default Ultra Gauge Mounting tip
I found out today that the mount that I have for my Sirus radio works for the Ultragauge. I have the one that hooks up to the ac vents. It is the same mount on the back of the UG. opens up new mounting possiblities.
Handy_Cruiser likes this.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 28 Jan 2014, 10:35 am
Default Re: Ultra Gauge Mounting tip
Nice! How about a picture?
You can also enter your idea here.
http://www.ultra-gauge.com/UltraGauge_Forum/
Old 03 Feb 2014, 05:18 am
sweet..how u like the guage??
Old 03 Feb 2014, 11:16 am
I would say I am the biggest promoter of the Ultra Gauge.
I own 3 2 are mounted in vehicles like my PT and the 3 I keep in a case to help others when out with the club or track. It is smaller then caring around one of my scan tools.
This might interest you?
PT Cruiser custom mount
Old 03 Feb 2014, 11:51 am
InfernoGT's Avatar
[/url]
That's an understatement. Nitro could sell an ultra gauge to a kid with a tricycle.
2006 PTGT with 5spd. ~60k miles
Old 03 Feb 2014, 07:36 pm
So far I don't really care for it. The MPH is off and very slow. I'm hoping that the boost preassure is right. I don't have a way to verify it yet. When it gets nicer out I will do some logs with the DSP and see if it is accurate. Other then that It has a lot of gauges that I really won't need. For the price it's good. Just my opinion.
Lenny
Old 03 Feb 2014, 08:08 pm
You have not calibrated your UG for your MPH? Like many precision instruments that need adjustments to be accurate so it is with the UG.
The MPH UG was correct on the Ford but I had to make calibration adjustment for the PT. It read about 1 MPH faster then the GPS.
http://ultra-gauge.com/ultragauge/su...al_1_14_14.pdf
MPG Accuracy
For best results, UltraGauge should be calibrated for both distance measurements and fuel measurement. See the following section:
Calibration... . Diesel vehicles must perform fuel calibration otherwise MPG and fuel gauges will be dramatically inaccurate. Vehicles
which use a Manifold Absolute Pressure (MAP) sensor instead of a Mass Air Flow (MAF) sensor should also see the following section:
VE Enable (MAP only)and ) VE RPM (MAP only). )
To determine which sensor your vehicle uses see this section: Version.
MPG Accuracy
MPG Accuracy
Old 03 Feb 2014, 09:32 pm
I'm not sure why they don't give you anything with the gauge. I had a pen and paper ready when I booted it up but I didn't see anything that needed to be written down. IDK maybe I did something wrong. Thats for the instuctions. I'm sure that will help.
Lenny
Old 04 Feb 2014, 01:15 am
How did you get the serial number for your registration? Did you take their funky little test?
Naw ....you did nothing wrong there just is a couple area's that need calibrating for
accuracy.
Old 04 Feb 2014, 02:22 am
I didn't get a serial number. What test are you talking about? I feel like I'm missing something here. registration? Where do I do that?
Lenny
Ultra Gauge podo2000 Tech & Performance Forum 16 02 Feb 2014 11:50 pm
ultra gauge users Crid Tech & Performance Forum 10 08 Oct 2013 04:11 pm
Ultra Gauge users jwv3 Tech & Performance Forum 5 09 May 2013 01:53 am
Boost gauge mounting option DMW General Turbo Discussions 8 20 May 2005 09:47 am
Mounting a boost gauge Mean Green Turbo Performance 2 19 Sep 2004 10:09 pm
