PT Cruiser high rpms and strange acceleration issues
  • 1 Post By pluminator
Old 28 Jan 2014, 04:08 pm
Default PT Cruiser high rpms and strange acceleration issues
Cruiser just wants to go, even with break applied.
I’ve never posted on these forums before so forgive me if I managed to mess something up along those lines. But here we go.
I was on my way home with my wife today after running some errands, it was a mix of street and high way driving. As we got off the highway and went to turn down one of our side streets I realized even as I let off the gas and began to push on the break the car still wanted to ‘drive forward’. The RPMs were sitting at around 2,000. Thankfully it was very light traffic so I never had to try and get it to a complete stop until we got to the stop sign before turning down our street.
Here is where it go scary, as I slowed down the RPMs went up, somewhere between 3,000 and 4,000 and just wanted to keep pulling the car even with my foot firmly on the break. So at the stop sign I cut the ignition, gave it a moment and started back up. It immediately jumped up in RPMs and tried to pull us forth. So I shut it off again and restarted it. This time I just threw it into drive and let it pull me, giving it enough gas to get us down the road. But as we turned onto our street and got going it leveled out. Idle went back down and it no longer seemed like it wanted to force me forward.
And now that I am home and have let it sit all seems well. I checked under the hood, the vacuum tubes I can reach seem solidly in place around the TB near the intake. (I am not a car guy, but I did some research prior to writing this). The hoses seem secure, I cant see or feel any leaks (not that it couldn't be else where), the TB seemed clean, not gunked up despite being a high mileage vehicle.
So really I am at a loss, I don’t really know where to look and my first thought was transmission because of the RPMs and such when shifting into gear, but really I am grasping at straws. ANY help on this would be much appreciated. Thank you.
Old 28 Jan 2014, 04:15 pm
garkeller's Avatar
Default Re: PT Cruiser high rpms and strange acceleration issues
My primary thought would be if the throttle cable got in a bind between the pedal and the TB and then if maybe an aftermarket floor mat caused any issue (both have happened to me in older cars)
Anyway, welcome to the forum and glad you and the mrs didn't get hurt with that gremlin attack!Gremlin.jpg
Old 28 Jan 2014, 04:20 pm
It is a 2001, so it definitely has some years behind it. If it is the binding of the cable as you mentioned is there a way to decrease the chance of it happening? I do not know if it makes a difference, but we live in Michigan, and the snow and cold has been hell this year, so I don't know if that could bring about any troubles.
But thank you again for your reply! We are hoping it was something temporary.
Old 28 Jan 2014, 08:38 pm
I would check the inside of the throttlebody for build up.
If its caked with black gunk it will actual cause the throttle to stick open and not close all the way, thus causing the car to continue accellerating. If its dirty, remove it from the car and clean it out with choke cleaner, but make 100% sure its fully dried before re-installing :-)
Old 28 Jan 2014, 08:59 pm
Was the temp gauge reading normal during this? Assuming so, maybe lub the tb pivot maybe hanging open. Inspect the cables to see if anything is out of place. Zip tie the vac hose ends you can get to. Do you have a check engine light?
Old 28 Jan 2014, 09:23 pm
garkeller's Avatar
I'm unfamiliar with what hard cold temps can do to a vehicle as I've always lived in Florida...is it possible for the steel cable to freeze/ice up in the line? It def sounds like something along the TB cable/connections/internal so I would say a good cleaning along all that area to see...good luck and stay safe! Make sure you use actual TB cleaner as it's safe on the exposed sensors in the TB area!
Old 28 Jan 2014, 09:25 pm
Attachment 9994
Except the air intake temp sensor!!!!. BAG THAT! I toasted mine with TB cleaner last summer :-p haha
garkeller likes this.
Old 28 Jan 2014, 09:31 pm
garkeller's Avatar
I know what you mean Plum...I hate that little delicate thingie that just sorta sticks out waiting for something to bang against it while doing motor work!
Old 28 Jan 2014, 09:45 pm
Thank you all for your quick and informative replies! I am going to take the time to get up in there and see just how dirty it is. Curious glance it seemed fine, but I was pissed off and probably not the most reasonable at the time. So I will take a look at that and trace the cables and make sure its all good. I'll be sure to watch out for the sensor and bag it if cleaning is done so I don't screw it up.
I will probably get to it all by this weekend and post an update then on how things went. Thanks again for the advice, it really gave us a good direction to go with.
Old 28 Jan 2014, 09:50 pm
If its a continuing problem, You can just pull the intake hose off and take a cloth to the inside of the TB for a quick clean out, should give some effect :-) that way you can have a semi-normal acceleration until the weekend, takes about 2 minutes :-)
Tags
acceleration issue, high idle, high rpms
Strange Siren Noise upon acceleration Cali777 General Turbo Discussions 6 11 Jun 2012 06:04 pm
High Idle and Cooling issues shadowsnkx Tech & Performance Forum 0 06 Sep 2011 08:55 pm
Engine surging at 4000 RPMs along with shaking at 2000 RPMs... brian5060 Tech & Performance Forum 3 24 Jul 2010 07:42 pm
Stutters during acceleration at low RPMs 2004PTGT General PT Cruiser Discussions 14 13 Jun 2009 10:17 am
Computer Causing PT Cruiser to Stall at Low RPMs/Turns??? pulpjava General PT Cruiser Discussions 7 26 Mar 2009 06:38 am
