New PT owner here...with a BIG problem
Old 30 Jan 2014, 06:09 pm
Default New PT owner here...with a BIG problem
Hows it going fellas..i just bought a cruiser, i have always loved these cars. the issue...it seems as if all the transmission oil has leaked out between the block and the trans...i have read that it needs a seal (i have no ides what seal or where this seal is)...but what i want to know is if i need a new transmission, or if changing this seal (i realize that the trans may have to come out)...will fix the problem.
anyone
Old 30 Jan 2014, 06:59 pm
UptownSport's Avatar
Default Re: New PT owner here...with a BIG problem
I'm not aware this is a common problem- I understand the solenoid pack leaks out, but that's up front.
Assuming it is an automatic.
Old 30 Jan 2014, 08:12 pm
mityqwik's Avatar
welcome to the forum
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 31 Jan 2014, 08:59 am
Where would the solenoid pack leak out from....and yes, automatic.
Old 31 Jan 2014, 01:05 pm
The pack is on trans front. There's lots of threads on this.
I'm not an expert on this, so my advice is limited.
Old 31 Jan 2014, 09:51 pm
767skyking's Avatar
Chrysler had some problems with torque converters leaking at the welds... Might be the problem.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 01 Feb 2014, 11:37 am
Thanks guys....so would replacing the tranny with a good working used one be a good idea? What do you guys think? I found a used one that has had the solenoid packs replaced from the dealer about 30k miles ago.
Old 02 Feb 2014, 12:01 pm
anything guys?
Old 02 Feb 2014, 12:54 pm
Welcome
Pretty much a blanket statement when you are dealing with a "good working used one". First, how do you know it works well? Are you buying it from a private individual you trust, or from a salvage yard? Next, a visual inspection is in order - fluid color/smell, looking for leaks, broken bolts, stripped holes, broken mounts, etc. And personally I never install a used trans without changing the converter, axle, dipstick tube, shift shaft, and any other seal that I can. Check all the torque struts and suspension stuff, like LCA bushings, half shafts and axle bearings - all common replacement items. And another important but often forgotten step - FLUSH THE COOLER.
Hope this helps.
Old 02 Feb 2014, 02:11 pm
767skyking's Avatar
If the original transmission is operating fine, pull the trans and figure out if it is leaking at the shaft seal or converter and replace what is needed. There are shops in our area that will do "soft" rebuilds (clutch plates, gaskets and seals) for about $650, which includes a reman converter.
Are you a PT owner or a Chrysler owner? purple04 General PT Cruiser Discussions 55 04 Sep 2014 09:57 pm
New PT Owner with a problem dantheman General PT Cruiser Discussions 14 14 Sep 2011 04:08 am
Another new owner Gremlin Welcome New PT Cruiser Members 14 01 Aug 2011 03:28 pm
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
