PT Won't Start
Like Tree16Likes
Old 01 Feb 2014, 08:06 am
Default PT Won't Start
Hey guys, got a Private Message from a guy named Mike who supposedly spent $3,000 trying to get his PT to start. His message is below. The only thing I can think of is that he might have got the timing off 180 degrees because he's practically replaced everything else. Any body got any other ideas?
Message Follows:
I am in severe distress with my pt!
HELP
Timing belt broke, replaced all belts, would not start.
Replaced crank, cam sensors would not start.
replaced coil and plugs would not start
complete valve job (in case I bent valve) would not start.
replaced PCM...Took it to dealer to reprogram...would not start. They wanted and additional 15 Hours for diagnostics.
Getting Spark, Plenty of fuel (Spark plugs wet)
Vacuum good.
It has all the components to start but all it does is turn over with not even a hint of fire. So 3K later my PT doesn't run. I am out of money and out of ideas.
Mike
garkeller likes this.
Old 01 Feb 2014, 09:27 am
Default Re: PT Won't Start
I would recommend verifying the timing - even experienced guys can have it off by 180.
mfrancis61 likes this.
Old 01 Feb 2014, 09:40 am
Ditto, but how mechanical is he? A compression gauge would tell if there is no compression. But I'm thinking best to go back in and do it again. And take pictures to verify that all is right before putting back together and to also start before putting covers and balancer back.
Old 01 Feb 2014, 09:57 am
767skyking's Avatar
Busted has given you a great suggestion!
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 01 Feb 2014, 10:20 am
Agreed - and a compression test would confirm that timing is off (or, less likely, that valves got hosed).
Old 01 Feb 2014, 10:29 am
That would make them inexperienced
Old 01 Feb 2014, 10:33 am
My suggestion is to first have a second eye look at everything first. Sometime we become blind to an obvious thing because the brain tells us things are correct.
Why is this person not on this thread?
There are q&a that should be done directly to the person. We are not a diagnostic school in testing on the verbals of a hypothetical problem as a team?
Old 01 Feb 2014, 10:35 am
Busted's suggestion is the best starting point fir an action plan!
Old 01 Feb 2014, 10:36 am
I've had several people come directly to me (?) with questions and most of the time I direct them to the forum to get answers. This time I just posted it here and I answered him by giving him the link to this thread.
Old 01 Feb 2014, 10:42 am
I just try to be of help. Anyway it comes. I know were to come when I need some lol.
Car won't start duck3233 Tech & Performance Forum 3 20 Oct 2013 03:32 pm
WILL NOT START bull Tech & Performance Forum 0 29 Mar 2012 05:33 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
New to this, where to start? havocxrush General PT Cruiser Discussions 6 15 Oct 2009 10:24 pm
PT Won't start... morrises General PT Cruiser Discussions 5 16 Jun 2008 09:57 am
