P0480 - Cooling Fan Relay but weird...
  • 1 Post By CREWZIN
Old 02 Feb 2014, 12:46 pm
Default P0480 - Cooling Fan Relay but weird...
Trying to help a friend work on his car. He has an '06 non-turbo. His car was overheating and I found out his low speed fan had quit working. Also noticed the fuse had blown for the fan motor. Replaced the fan motor and the fuse. Fan didn't work. Replaced the relay and then it starts working but has the code P0480 Cooling Fan Relay 1 Control Circuit. Whats weird is when you turn the car off and restart it the fan won't work. With the car running, pulled the relay and put it back in and it starts working. What is even weirder is that tried it again, pulled the relay, and then the fan turns on with the relay out. How in the heck would the fan run with the relay out?
I am going to have him replace the relay again but I do not know what is going on here.
Old 02 Feb 2014, 01:44 pm
Ray_Dockrey's Avatar
Default Re: P0480 - Cooling Fan Relay but weird...
If you replaced the fan unit you replaced the relays as they are all part of the fan unit. So which relay are you pulling? The ones mounted on the fan shroud or somewhere else.
Old 02 Feb 2014, 01:51 pm
There are not any mounted on the shroud. It is just the one that is in the distribution box next to the master cylinder. I was looking around online though and it looks like the '06 and newer should have them on the shroud but his doesn't which is weird.
Old 02 Feb 2014, 03:34 pm
VNT's Avatar
VNT VNT is offline
So you replaced his fan module(fan, enclosure, relays) and now he still has an issue?
I just replaced mine with a new mopar fan module(250 clams), replaced the 50A in cavity 11 and everything is fine.
Note when my original fan module failed, you could smell burnt electrical and next day the CEL tripped. I ordered the new fan that evening, dealer cut me a deal on the fan and had it next morning.
VNT
89 Shadow ES 2.5 T2 +20's A555 sold
90 Daytona ES 2.5 T1 A523
90 Datyona Shelby VNT needs work
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
03 PT GT Black 5 sp Stg 1
05 PT GT Silver 5 Spd Conv
Old 02 Feb 2014, 03:52 pm
Removed the fan and shroud from car. I took the fan blade off and replaced the motor. Replaced the fuse and the relay in the distribution box. There are no relays on the shroud like I have seen in some pics online. The only relay I see for it is the one in the distribution box. It is something to do with the relay now. Fan runs great but doesn't come on unless you mess with the relay. I just don't understand how the fan runs with the low speed relay out in my hand.
Old 02 Feb 2014, 04:33 pm
Robert, I don't pretend to know your answer, but I do have questions: YES the 2006 to 2008 (and maybe more) radiator fan is supposed to have TWO relays near the top of the fan (as you have seen in pictures). Those relays attach to electrical connections near the top of the fan. Do you NOT have those two connections that attach to the relays that are supposed to be on the fan? If not, and you do buy a 2006+ radiator fan with the relays attached, you don't have the electrical connection to go to those relays, correct?
If you don't have those connections, somebody jury rigged something so the fan would work without the relays (attached) and that's why it's running without the relay in the distribution box. Maybe somebody bought the wrong fan (01-05) and did some work on the car so the fan would run?
Don't know if I made myself clear or not but you are right saying the fan should NOT run with the relay out of the dist box...unless someone might have done something to get it to run.
bert57 likes this.
Old 03 Feb 2014, 12:07 am
I will make sure his car is not an '06 but he says that is what the registration says. It seems like though it would be an '01-'05 with the fan setup. The fan on the car did not have the relays attached to it and the one I replaced it with did not also. I will have to do more investigating.
Cooling fan relay 2 circuit location... jcmnz24 General PT Cruiser Discussions 4 28 Sep 2013 02:06 pm
Cooling fan relay ? facts Tech & Performance Forum 11 22 Aug 2013 10:58 pm
Cooling Fan Relay bowrock General PT Cruiser Discussions 2 19 Dec 2012 08:32 am
Radiator/cooling fan relay part number for PT 06? TwoCats Tech & Performance Forum 23 24 Jan 2012 10:35 am
Weird Cooling Issue TurboDucky Tech & Performance Forum 3 31 Dec 2011 01:40 pm
