Need help! 2001 Pt cruiser!!
Old 03 Feb 2014, 06:46 pm
Exclamation Need help! 2001 Pt cruiser!!
I have a 2001 Pt cruiser 150,000 miles bought used a year ago. When the weather got in the negative temps. My car wouldn't start and battery died (or so it seemed) I tried jumping it and it wouldn't start so I took the battery out to autozone and the battery was fine and they fully charged it I hooked it up today and the car won't start. All lights are on,it sounds like it wants to start but won't. I don't think it's the starter. I put a code scanner on it and came back with no codes I also did the odometer can and it came back with p1684 which is just that the battery had been disconnected. I think it might need maybe reset? I honestly have no idea?? Anyone know what could be wrong.
Old 03 Feb 2014, 07:09 pm
Default Re: Need help! 2001 Pt cruiser!!
Is the starter working? Turning the engine over? If it is try this.
Feather the gas peddle, the ecu needs to relearn the map/tps sensors. Hold rpms @ 1200 until the car will idle.
2003 GT- Stage 1, Mopar BOV, 2.75" catback, Hurst SS, Eibach pro-kit, 6000k fogs, Alpine CDA 7893, 10" Alpine Type-X powered with JL Audio e1400d, Alpine Type-R components powered with JL Audio e4300.
Old 03 Feb 2014, 07:15 pm
The starter is working and when crank it feels and sounds like it wants to start but won't.
Old 03 Feb 2014, 07:31 pm
randyincctx's Avatar
Lightbulb Re: Need help! 2001 Pt cruiser!!
Check ALL cable connections(not just terminals) paying special attention to the fenderwell ground(it is vunerable to corrosion from road salt!),if all appear OK....You may want to check them for resistance with a multimeter,as cables do have a tendency to breakdown with age,causing greater resistance,thus not allowing all of the voltage/power to get where it needs to go.
Aka:~KILLER~
Old 03 Feb 2014, 08:00 pm
All lights,radio,alarm etc work
Old 03 Feb 2014, 08:26 pm
Get some starting fluid and spray into air intake and crank it over...
If it doesn't catch with THAT, you have no spark....OR - the timing belt snapped.
When was last time timing belt was changed? Needs to be changed every 100,000 miles - if it wasn't changed, I'll bet that's your problem.
Old 03 Feb 2014, 08:53 pm
I don't think it's the timming belt as it was replaced a year ago and I haven't driven more then 5,000 miles
Old 03 Feb 2014, 08:57 pm
Well good, that trimming belt is very important
Originally Posted by Dailey21 View Post
I don't think it's the trimming belt as it was replaced a year ago and I haven't driven more then 5,000 miles
Old 03 Feb 2014, 09:36 pm
try this:
Old 03 Feb 2014, 09:54 pm
garkeller's Avatar
Ouch...cranking but no starting...could be timing belt blues...but with only 5K on a new one...maybe cam sensor?
2002 Chrysler PT Cruiser Base (2.4/automatic)
2000 Chevrolet Blazer LT 4dr SUV 4WD
1998 Ford Mustang Sport (3.8/automatic)
1974 Jeep DJ-5C (4.2/automatic/LH drive)
1973 Chevrolet Nova Sedan 350 (automatic)
2001 pt cruiser please help RogenskiAmanda General PT Cruiser Discussions 4 02 Dec 2011 12:52 pm
2001 PT Cruiser TBURG PTS Classifieds: For Sale/Trade 12 04 Apr 2011 01:00 pm
2001 PT cruiser rim ericamao Wheels, Tires, Suspension 1 03 Dec 2010 05:47 pm
2001 pt cruiser pt_ Tech & Performance Forum 1 17 Sep 2010 11:51 am
