FOG LIGHT FUSE POPPING
  • 1 Post By Tucker05
Old 04 Feb 2014, 05:40 pm
Tucker05's Avatar
Default FOG LIGHT FUSE POPPING
I just replaced the multifunction switch and then the non flashing relay and before i can put the fuse in completly it pops. ???? idk what it could be !!
Old 04 Feb 2014, 11:04 pm
Tucker05's Avatar
Default Re: FOG LIGHT FUSE POPPING
ok so here i go...
Fog Lights stay on (no #15 fuse) / Bought a MFS
Installed it (installed #15 fuse) / fog lights worked as designed
Took it for a test drive (just changed oil too)
NO BLINKERS / NO WIPERS
Check lights and headlights and fogs work.
Replaced NON Flashing Relay.
#15 fuse popped
Cant keep a fuse in there. I cant figure out what is the problem. It pops every time.
Old 05 Feb 2014, 02:10 am
randyincctx's Avatar
Lightbulb Re: FOG LIGHT FUSE POPPING
Sounds like you may have a short circuit somewhere;You should thoroughly check over the connectors & wiring to the MFS & fuse panel.
Pull the fuse panel,and look at the wiring from the backside....Look for any signs of 'burnt' wiring or connectors(signs of overheating).
Viewing the fuse block from the backside;The red arrow points to the tan/black wire at the center contact pin of the headlight relay,this wire goes to fuse #8 at the fuse block and exits as a pink/light green wire to pin #13 at the MFS.
The blue arrow points to fuse #8 wires.
Back of fuse panel with burnt/melted wiring:
MFS with burnt/melted connector & wiring:
Aka:~KILLER~
Old 05 Feb 2014, 02:11 pm
Tucker05's Avatar
I will have to do that, Im just stuck I ordered more relays and another mfs going to see what happens. This weather doesnt make it that easy.
Old 05 Feb 2014, 10:14 pm
Tucker05's Avatar
figured it out ..... aftermarket part suck !! Im sorry. I dont know how the car knows it.. but it doesnt NOT like them at all lol
randyincctx likes this.
Old 05 Feb 2014, 10:43 pm
Cool Re: FOG LIGHT FUSE POPPING
About 99% say ALWAYS use Mopar replacement electrical components,1% say OEM has worked OK for them.........But,you are another to report having problems after replacing with OEM electrical part(Especially the MFS).
Mechanical parts are OK to replace with OEM,but some believe the problem with OEM replacements,are they are sometimes manufactured in less the 'clean room' conditions,which is NOT good at all for electronic components(Even a speck of dust on a circuitboard can cause BIG problems sometimes!)
Aka:~KILLER~
Front Fog Light Fuse Jassy General PT Cruiser Discussions 32 17 Aug 2014 02:32 pm
MFS and fog light fuse kariered General PT Cruiser Discussions 3 15 Jul 2012 11:35 am
Fog Light Fuse- Location? MissRixatrix Tech & Performance Forum 5 11 Oct 2009 03:54 am
Fog Light Fuse SuperTroy Exterior Accessories Forum 1 17 Aug 2007 06:50 am
Fog Light Fuse bkarr Exterior Accessories Forum 3 15 Apr 2007 08:43 am
