pulleys seem OK.. why wont the belt stay on!?
Like Tree2Likes
  • 1 Post By Busted_PT
  • 1 Post By rob342
Old 08 Feb 2014, 04:51 am
Default pulleys seem OK.. why wont the belt stay on!?
Hey cruisers, I'm a bit stumped and need some guidance..
I noticed my accessory belt slipped off, so I took off the splash guards to check if any of the pulleys were seized or if the belt had broke. The tensioner, power steering, and a/c pulleys all moved freely so I put the original belt back on.
The belt pops off with the first turn of the engine when I start the car.
Should I try a fresh belt? Could my compressor not spin when the clutch is engaged? Does anyone know what the culprit could be?
Old 08 Feb 2014, 04:57 am
Default Re: pulleys seem OK.. why wont the belt stay on!?
You can turn the compress by hand to see if it locks. Most likely your tensioner is bad. Check for wobble.
Old 08 Feb 2014, 01:13 pm
UptownSport's Avatar
I think the question was if the compressor was locked- So it would spin when all was off (electric clutch disengaged) but as soon as powered the clutch would engage a seized pump?
Old 08 Feb 2014, 02:01 pm
if it's happening that soon, pull the connector off the cam sensor and have someone crank it while you watch
Busted_PT likes this.
Old 09 Feb 2014, 06:56 pm
Uptown,
The flywheel spins freely when all is off, but I do not know if the compressor is seized once engaged. Can I check if the compressor is seized by starting the car, turning on the a/c, and trying to turn the flywheel once the a/c Clutch is engaged?
Rob,
How would I remove the can sensor? I assume watching the belt come off could give me the answer I'm looking for
Old 09 Feb 2014, 06:59 pm
Busted,
With the car off I can turn the flywheel and it will eventually lock if the compressor is seized?
The tensioner seems ok, but I will take a closer look for wobble or slop.. It definitely still has plenty of tension
Old 09 Feb 2014, 07:57 pm
Busted,
You can turn the ac pump not the the engine. just reach up and spin the end that sticks out the furthest from the pump. But you would hear all manner of screeching if something was locked up.
replaced timing belt, wont stay on!! daasolu Tech & Performance Forum 28 28 Apr 2013 12:23 am
Replaced Headgasket,Timing Belt & Pulleys, but not running just right yet... UofKguy Tech & Performance Forum 5 07 Jan 2012 02:33 pm
After timing belt wont start moparman75 Tech & Performance Forum 1 17 Apr 2011 10:39 am
amp wont stay on bhunt41 Sound and Security Forum 5 14 Jan 2011 04:23 pm
03 GT Cruiser wont stay running. 03GTCruiser Tech & Performance Forum 2 23 Feb 2010 12:14 am
