UltraGauge users...
Old 10 Feb 2014, 07:21 pm
Default UltraGauge users...
Do you have an Intake Air Temp, Fuel Level Sensor, or AFR Ratio options?? I get the "No Fuel Sensor Found" response when checking the Fuel Sender Mode.
I don't have these options on my 2002 2.4L Touring Edition. Curious if you do or these sensors/gauges are just not available to this model or the PT in general.
TYVM,
Morgan
Old 10 Feb 2014, 08:05 pm
Default Re: UltraGauge users...
I have an ait set up on mine. The fuel sensor is obsolete (afaik) and the only way to pull afr is with a wideband gauge.
Old 10 Feb 2014, 08:15 pm
rckstein's Avatar
I an an '06 Touring Edition, I have an Air Intake Temp and Fuel Level Sensor, not sure about the AFR Ratio, would have to check that.
Old 14 Feb 2014, 12:25 pm
Anybody else have any ideas why I would not show an Air Intake Temp or Fuel Level Sensor?
Nitro maybe??
Old 14 Feb 2014, 12:41 pm
I couldn't tell you about the fuel issue without a service manual but the IAT you should be seeing? Does it come up as an option in the gauge menu for a page?
Old 14 Feb 2014, 02:47 pm
podo2000's Avatar
I have mine in a 05 Touring auto. Also says fuel sensor not found.
2004 PTGT 135Kmiles
Old 14 Feb 2014, 08:30 pm
Hello Nitro - No it does not come up on the list. I'll look thru my SM about the fuel sender & see what I can find.
Old 14 Feb 2014, 08:44 pm
Here's a transcription of the 2001 - 2003 FSM. Sounds like it should be there to me.
FUEL LEVEL SENDING UNIT / SENSOR
DESCRIPTION
The fuel gauge level sending unit is attached to the side of the fuel pump module. The level sensor is a variable resistor.
OPERATION
Its resistance changes with the amount of fuel in the tank. The float arm attached to the sensor moves as the fuel level changes.
The fuel level input is used as an input for OBD II. If the fuel level is below 15% or above 85% of total tank capacity several monitors are disabled. There are diagnostics for the level circuit open and shorted.
Old 14 Feb 2014, 11:41 pm
I looked in my available gauge perimeters for the PT in the UG and I do not see the option. I sent a question to UG about it.
The IAT is there.
Old 15 Feb 2014, 12:18 am
rckstein's Avatar
The fuel sensor is not set on one of the pages of gauges, go to: Ultragauge Setup > Version > you should then see the screen in the below pic that displays if Fuel Sender is available or not for the vehicle. If available, then go to: Fuel Menu > Level Sender Mode then you can select: Disable/Enable/Smart.
This UltraGauge is running on an '06 Touring Edition.
NitroPT likes this.
UltraGauge For All compdr59 General PT Cruiser Discussions 23 14 May 2013 12:41 pm
245/45/18 users Stephen R. Tech & Performance Forum 0 10 Feb 2002 10:50 pm
