Please help my pt is dead
Old 12 Feb 2014, 04:22 pm
Default Please help my pt is dead
Ok so I was driving yesterday and all the sudden the car shuts off I have power fuel and spark replaced the cam sensor what else can it be just turns over but dosent start I also pulled a plug out and the tube was full of oil so I kno it's needs a valve cover gasket but would that short anything out you guys input is appreciated thanks in advance.
Car has 213xxx on it please help it's my only car
Old 12 Feb 2014, 04:45 pm
cruserdad1976's Avatar
Default Re: Please help my pt is dead
the answer is NO it would not
how long ago ws the timing belt changed???
how do you know you havce fuel--no in the tank but to the plugs
it can be a few things timing belt--fuel pump Pcm
if you are actually getting fuel to the sylender and if it is firing and if the timing belt is right it pretty much has to start so one of them is not there
Old 12 Feb 2014, 04:48 pm
Go with cruiserdad's first question, when was the timing belt done, or was it. What kind of mileage do you have. When you changed the Camshaft sensor did you look to see if anything is turning when you turned over the engine inside the hole where the sensor goes? If nothing turns, the belt is gone.
Old 12 Feb 2014, 04:57 pm
The cam sensor was done at 203xxx if I'm not mistaken but I didnt even think about the belt but I will check and also I have fuel at the rail so I'm sure it gettin to the cyl I also smell gas under the hood while trying to start but no leaks and the car is. 2002 2.4 n/a thanks for the replys
Old 12 Feb 2014, 05:05 pm
Also if the belt crapped out is the motor shot are they intermittent motors my honda I had crapped the belt and the motor was done for just seeing if I should start looking for a new car before dumping money in this one thanks in advanced
Old 12 Feb 2014, 05:10 pm
The PT 2.4 Liter engine is a non-interference engine which means the pistons can't hit the valves, BUT the free floating valves can hit each other. On average, only about 1% of the cars that had the belt break had internal damage. You should be OK. Hopefully.
If belt broke, odds are good you just need a new belt (and water pump) - usually doesn't cause any more grief, but belt & water pump runs about $1,000 +-.
Old 12 Feb 2014, 05:49 pm
Must've hit submit reply same time as Crewzin...
Old 12 Feb 2014, 08:39 pm
Well guys it's the belt it's 34$ I'm gonna attack it fri wish me luck
Old 12 Feb 2014, 08:51 pm
Wait!!! Have you ever done anything like this before? The best people around, it takes 5 to 7 hours and they know what their doing. A lot of mechanics get the timing wrong because they haven't done it before. Go into our HOW TO section and find the 5 threads that talk about the in and outs of doing the timing belt change. You also want to put a new tensioner and water pump on while your doing that job. Here's the link to the HOW TO section...
HOW TO's
CruiserLady likes this.
PT is DEAD bhunt41 Tech & Performance Forum 14 12 Jul 2011 04:22 pm
Is my PT dead? Marco421 Tech & Performance Forum 4 13 Dec 2010 09:34 pm
dead car klondikeone Tech & Performance Forum 4 09 Nov 2010 02:02 am
Dead PT need help benjibbad General PT Cruiser Discussions 7 26 Mar 2010 03:10 pm
Dead, again renichms General PT Cruiser Discussions 6 03 Jul 2003 10:42 pm
