New fuel pump, but now no fuel to front?
Old 12 Feb 2014, 06:29 pm
Question New fuel pump, but now no fuel to front?
Hello, been having a problem with my fuel system.
Changed the fuel pump, and tested to make sure the fuel was being pushed through by disconnecting the fuel line at the firewall. A steady stream shot out very strong. Hooked everything back up and raised fuel tank back, everything reassembled. Car started, ran for a few seconds, then quit, and would not start again. Just kept turning over and over. Disconnected fuel line at firewall again, and NO FUEL comes out anymore even though can still hear fuel pump priming when key is switched to on.
Any ideas would be greatly appreciated.
J
Old 12 Feb 2014, 07:18 pm
Default Re: New fuel pump, but now no fuel to front?
Either crud from the tank is blocking the pump, or you have a kink/break in fuel line - any gas under the car? Could you have pinched fuel line when you remounted tank?
rob342 likes this.
Old 12 Feb 2014, 08:08 pm
That's what i'm going to look for tomorrow when it warms up here... going to drop the tank again to be sure there's no kink. No there is no gas under the car. Tank is near full of gas at current moment, that sucker is heavy. Added gas to it after finishing the installation. It had great pressure before remounting the tank... so the kink in the line idea is the one I'm currently going with, too...
Old 13 Feb 2014, 11:04 am
i did that on my mustang, but i pinched the return line. i thought my adjustable FPR was busted, it wouldn't go lower than 65psi and i wanted it set at 40. i hope that's the problem. it does happen
Old 14 Feb 2014, 11:21 am
UptownSport's Avatar
Can you hear the pump run?
Old 14 Feb 2014, 01:03 pm
He says yes:
" NO FUEL comes out anymore even though can still hear fuel pump priming when key is switched to on. "
Old 14 Feb 2014, 01:21 pm
i'd guess the little 6" line came off the pump and inside the tank and it's making a cute little fountain in there.
Old 18 Feb 2014, 12:52 pm
Was there a solution found? I have a 2007 PT and i am not getting fuel to pump. I did cut an access panel and replaced the fuel pump. Still nothing. I can hear the pump for a second or two when I first turn the key. Any Help out there?
Old 18 Feb 2014, 10:34 pm
Timing belt broken? Cam position sensor failed or wiring bad?
Old 19 Feb 2014, 06:00 am
BigO; It is normal to hear the fuel pump run for a couple of seconds when you turn the key to ON. And then the pump will shut off if the engine isn't cranking over.
Tags
fuel pump, fuel system
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
fuel pump rob342 Tech & Performance Forum 13 18 Sep 2012 05:16 pm
fuel pump help twincruiserturbos General Turbo Discussions 10 29 Jun 2010 05:53 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel pump nevinsrt Turbo Performance 4 15 Aug 2008 09:03 am
