weirdest error code ever... HELP
Old 13 Feb 2014, 08:34 am
zkdawg's Avatar
Question weirdest error code ever... :help2:
now im not sure what happened but while i was reading a code (P0420)
all the sudden the code C22FF pops up from no where.
im not sure if it was an error on my laptop, my reader program (OBDwiz), or if it is a real code as i googled it and cant find anything at all on it.
if anyone has come across this before plz help
thx
with everyones exp., what is the P0420 all about and what could the problem be?
i looked it up and it could be the O2 sensor or an exhaust leak but im just trying to pick a few brains here.
Old 13 Feb 2014, 08:56 am
Default Re: weirdest error code ever... HELP
It could be the CAT or the downstream 02 sensor. Have you ever replaced either of the 02 sensors? What is the mileage on your PT? If it turns out to be the CAT, your covered under the emissions warranty for 8 years or 80,000 miles.
But first things first. Clear the code, get in/under the car and check both 02 sensors and the wiring to both to make sure their both n place and everything looks good. Then see if the code comes back after driving.
...and on that C22FF, I can't find anything related to the PT.
Old 13 Feb 2014, 09:13 am
Look at your manual for your scan tool, it may be an internal error code for the tool itself?
Old 13 Feb 2014, 06:12 pm
zkdawg's Avatar
thx for the info but i have an 01 with 195,500 miles and i just bought it.
the motor and trans were swapped out at 140,000 and they didnt have any records for this thing but i got the shops info that did the motor/trans so ill call them soon for info on weather or not they did new motor or used.
they did the timing belt before i bought it.
Old 13 Feb 2014, 06:13 pm
zkdawg's Avatar
if it was an error on my scanner then im sure it wouldnt put it in with the codes from the car.
Old 13 Feb 2014, 06:27 pm
Did you look at your scanners user manual for internal error codes? Just asking!
What is the model and brand of Diagnostic Scanner are you using?
We are just trying to help you.
I realize that I may have little experience with Diagnostic OBDII port access and DTC code interpolations and analysis but I do know how to read information on DTC codes available for most vehicles. The number you are giving do not come up in anyone's master DTC guide. So the conclusion would be a device operation error code which could be confirmed by the user manual or an technical service number of your scanner you could call to find out?
Old 13 Feb 2014, 10:09 pm
zkdawg's Avatar
i dont have a man. as it didnt come with one.
this is the one i have and i recommend it to anyone needing a reader ect. for a great price.
http://www.amazon.com/ScanTool-42300...eywords=obdwiz
Old 13 Feb 2014, 10:58 pm
I will find out about it tomorrow and let you know.
All can tell you is you should not have gotten the numbers as you described. Scanners do not work that way.
Old 14 Feb 2014, 09:51 am
zkdawg's Avatar
trust me i know.
i fig i just put it on here to see.
i just think something had a brain fart, but which brain?
Old 14 Feb 2014, 10:57 am
trust me i know.
Your response has me looking at your signature picture! ?
Error code awesome1 Tech & Performance Forum 3 31 Oct 2012 05:25 pm
error code 113 BeagleDad Tech & Performance Forum 17 22 Aug 2010 01:13 am
Error code 601 COOLSILVER02NV Tech & Performance Forum 7 14 Jul 2009 10:52 am
ERROR CODE PLEASE HELP Andrew514 General Turbo Discussions 2 27 Jun 2009 10:52 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
