Block Tester, blown head gasket
  • 1 Post By Busted_PT
Old 13 Feb 2014, 03:44 pm
Default Block Tester, blown head gasket
When checking for a blown head gasket with a block tester and fluid, do you check from overflow bottle on the back of the engine firwall or radiator cap spout where the thermostat sits?
Old 13 Feb 2014, 04:06 pm
Default Re: Block Tester, blown head gasket
From the radiator cap.
Old 13 Feb 2014, 04:14 pm
Originally Posted by NitroPT View Post
This chemical is used to find pretty much any coolant leak or seep in a head gasket joint between block and head. This device is essentially a tube that is filled with a green testing chemical that reacts only with combustion gasses.
More about this.
head gasket or water pump?
WELCOME TO THE FORUM.
Maybe you can tell us a little about your PT Cruiser?
Old 13 Feb 2014, 04:56 pm
cruserdad1976's Avatar
so you have to do the test WHILE eating some kind of Breand Flakes???????????
WITH YOUR LEFT HAND???????????????????????
Old 13 Feb 2014, 05:05 pm
Yes we know-it-all types need to keep up brain food. I am a forced right hand from birth that benefited me later as I learned to use both hands. So now I am pretty much ambidextrous. As a teenager this worked out well, like a different person.
Old 13 Feb 2014, 07:06 pm
Though that bran was to help with that s@%!y attitude.......
Old 14 Feb 2014, 02:59 pm
Never knew this. Jay Leno says he's been using this "waterless coolant" for over 16 years.
Check it out. Interesting.
Home Engine Cooling Systems
Old 15 Feb 2014, 05:17 am
Imark; saw the Leno video. Interesting. I don't think this product has the cooling capacity of water. As trucks having high capacity cooling systems was mentioned. During WWII kerosene was used by some in place of antifreeze! --- I'll stick with the Mopar stuff.
Old 15 Feb 2014, 10:55 am
That WAS interesting.
I thought about filling cooling system with oil - old VWs and Porsches were really oil cooled - but I think that oil is harder to pump (more viscous) than coolant.
Blown Head Gasket? sweng40 General PT Cruiser Discussions 20 14 May 2015 01:40 pm
Possible blown head gasket jksoft General PT Cruiser Discussions 11 16 Jan 2013 07:15 am
Possible blown head gasket txsoldier2012 General PT Cruiser Discussions 3 07 Jan 2012 02:45 pm
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
Blown head gasket fatboypt Tech & Performance Forum 2 14 Nov 2010 09:57 am
