20 Feb 2014, 01:39 pm
Re: Diagnosis of a cooling issue
Originally Posted by lmarkie74
I'm very new to this forum. Just bought a 2001 PT Cruiser a couple of weeks ago. The previous owner said his mechanic told him it had a blown head gasket. I didn't think so, it runs too good. He told me the radiator had just been replaced. I had him follow me to my house about 10 miles. As soon as we got there it start steaming up on the inside. I suspect heat core went. No biggie for right now. Summer is getting near. I'll deal with that later. I did a block test with the chemical and no HC's were present. Kinda hard to do it though. Bubbling and spitting through filler neck.
I have bypassed the heater core, replaced the thermostat, replaced the cap, and have replace the filler neck just in case it has a crack in it that I can't see. $13 at Advanced Auto. Cheap! Fan works. Comes on when it's suppose to.
Here is my biggest problem. Once the temperature gauge gets to half way, coolant/water pushes out from under the new cap.
What is this a sign off?
Originally Posted by Handy_Cruiser
I test drove several PT's before I bought mine. And two with blow head gaskets acted exactly like this.
The head doesn't leak until the engine heats up. Then it blows the coolant out before the coolant get really hot. Often the coolant will not even burn you when first blowing out. And pressure testing and such may be inconclusive on this condition.
I good way to test this is to remove other variables. First assure your radiator is in fact new. Then remove the thermostat all together. Fill the car with water assuring there are no air pockets and then start the engine with no radiator cap. If the head gasket is good, some water may come out of the open radiator with no cap, but it should level out and circulate normally. Also the fan should operate normally. After running for a while, the engine should approach normal operating temperature unless it's really cold where you are. And there should be no or very little water coming out of the radiator.
But, if the PT runs for five to ten minutes and then belches out practically all the water, then you can just about bet it is the head gasket. Again, this appears to be a very common issue with early PT's.
Handy aka MR T., I reposed your quote because generally it is ok information but did you read what I highlighted in RED? A blown head gasket or cracked head can't hide form this!
" Share you knowledge. It's the best way to achieve immortality."
