03 Transmission Problem
Like Tree2Likes
Old 20 Feb 2014, 03:38 am
Default 03 Transmission Problem
My girlfriends pt has started acting strange sometimes. Sometimes it doesnt want to change gears. its an auto trans. You'll have to pull over and shut the car off, but you can start it right back up and it shifts fine. anyone have any ideas what it could be.
Old 20 Feb 2014, 07:13 am
Default Re: 03 Transmission Problem
Mike, what mileage does your GF's PT have and has the trans ever been flushed?
Old 20 Feb 2014, 02:17 pm
It has a little ove 200,000 miles on it. I did change the fluid and filter the other day but that didn't help. I didn't do a complete flush. It only does it every now and again. It might not do it for a month. I was thinking it may be something electrical since you can shut the car off then start it up and its fine.
Old 20 Feb 2014, 02:23 pm
Now that is a record of sorts for a PT with an automatic 200,000K +miles!!
It sounds more like fluid pressure related. You may get some ATX fluid additive/treatment like Red Line or Amzoil. It may help what may be simply some varnish build up around the servos and or the solenoids. You could get the transmission TCM scanned but I do not see the need at this time given the infrequency of the issue?
Busted_PT likes this.
Old 20 Feb 2014, 02:39 pm
I'll try that. I forgot to mention that their are no check engine lights or anything.
Old 20 Feb 2014, 02:45 pm
Mike, you would not necessarily get a PCM, DTC from the TCM. So it is inconclusive.
Old 20 Feb 2014, 03:51 pm
Ok, I'll get some of the atf additive and try that.
Old 22 Feb 2014, 06:39 pm
I have over 218,000 on my 2007. It does start shifting slower when the fluid lever starts to drop. It has a leak so i do have to keep my eye on it.
Old 22 Feb 2014, 06:45 pm
WOW!
I love reading about these automatic's going on with so many miles!!!
If this keeps up it may be another forum myth about the PT Cruiser automatics failing with low miles on them?
Old 22 Feb 2014, 07:06 pm
Originally Posted by NitroPT View Post
WOW!
Just with anything. You will have both extremes with almost anything. I've seen many autos with lots of miles with the chrysler 4 bangers.
Transmission problem rodrigoaba Tech & Performance Forum 8 17 Apr 2013 12:33 am
transmission problem?? deafy06 Tech & Performance Forum 0 26 Jul 2012 05:54 pm
Transmission problem csd Tech & Performance Forum 1 20 Jul 2011 01:22 am
Transmission problem klarens Tech & Performance Forum 3 17 Feb 2010 06:23 am
Transmission problem Syl General PT Cruiser Discussions 4 20 Sep 2008 09:50 pm
