| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
I'm wondering what is done to the PT for the 30K service?
Dealer said $399. Seems high. Besides lube, oil, filter, and spark plugs, why is it so expensive? I'll do it myself but would like to know if the are better plugs to use other than factory. I've got an air-aid, spacer, & dual exhaust and wondering what else to do. Getting 25-26 MPG at 70-75 MPH. Any help would be appreciated. Thanks, Greg |
My dealer charged $282. They did what is in the owners manual for the 30,000 mile checkup. If you do your own keep records and detail what you did and keep receipts.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
The schedule only calls for replacing the spark plugs, air filter, and PCV valve.
Then they should "inspect" the suspension and belts. That's it. That would cost about $100 at my shop. You got screwed. |
And there is no "lube" any more - if you're lucky they'll smear some grease on door hinge....
The Champion Platinum plugs are the way to go - I have not seen a single post with problems with the champion platinums - they last longer than the copper.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
Thanks for the info... I'll change plugs and PCV valve, then take it
to shop where they do oil change, filter, rotate tires and wash vehicle for $29.95... I'll use Champion Platnium Plugs...Question, do I get single platnium or double?? Also how long do these plugs last and what is gap and part #: ? Thanks, Greg |
alt oflace the 30k is oil change air filter trans service tire rotate pcv valve throttle body/intake cleaning spark plugs i recomend the stock ones, the reason it the platinum tip can get to hot and glow causing detonatioin.
\'03 pt gt s1 mopar bov auto patriot blue 1925 modle t pulling truck w/864hp 673ft/lb 2002 harley, 1998 zrt 600 cat http://cpatrucks.org/members/endres.html |
brngrhd just an fyi the double platinums 7440 work fine in the na cruiser , actually better than stock . However you are correct about using them in the GT or turbo lite .
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp |
Nowhere in the service schedule in the owner's manual does it call for throttle body service or injector cleaning. The tranny fluid is not called for at 30K miles.
Stick with the schedule for your car. |
| 30,000 mile maintenance | parkertam | General PT Cruiser Discussions | 5 | 15 Feb 2007 02:46 pm |
| 2 FOR THE PRICE OF $35! CHEAP SERVICE MANUALS! | Wicked_PT | Classifieds: For Sale/Trade | 0 | 05 Jun 2006 02:56 pm |
| 30K mile service on 2001PT, >$700? | gychang | General PT Cruiser Discussions | 14 | 14 Dec 2005 04:25 pm |
| 30K mile service on 2001 PT, nonturbo | gychang | Tech & Performance Forum | 5 | 09 Dec 2005 11:46 am |
| 30,000 Mile Service $ Yikes!! | BB | General PT Cruiser Discussions | 8 | 23 Jun 2004 08:02 pm |
