01 Pt Issues
  • 1 Post By randyincctx
Old 23 Feb 2014, 01:17 pm
Default 01 Cruise Control quit working
I got a basic plain jane 01 pt that needed a head gasket. I replaced the head gasket and got everything working good engine wise.
The car didn't come from factory with cruise or fog lights.
I got all the cruise parts (mine had the wiring in it from factory) and put them in, worked good for about a day. Now it will not even turn on the cruise light in dash or work at all. I was wondering if anyone else had this kind of problem.
Is there a way to test the clock spring or cruise switch independently ?
With the fog lights the wiring was there out front for the bulbs but there does not seem to be a socket in the #8 fuse spot for a fuse
Old 23 Feb 2014, 03:43 pm
Default Re: 01 Cruise Control quit working
"omnicrazy "I got a basic plain jane 01 ...
I got all the cruise parts (mine had the wiring in it from factory) and put them in, worked good for about a day. Now it will not even turn on the cruise light in dash or work at all...."
RE: cruise control, several possible failure points.
Check fuse #10 in the dash fuse block
"With the fog lights the wiring was there out front for the bulbs but there does not seem to be a socket in the #8 fuse spot for a fuse"
The car's front light harness has the fog wiring. The dash harness does not so you will have to do some DIY wiring.[/QUOTE]
Old 23 Feb 2014, 04:20 pm
Checked the #10 fuse it is ok
When the clock spring goes bad would the horn/ airbag still work?
Old 23 Feb 2014, 05:02 pm
Default Re: 01 Pt Issues
I took the airbag out to make sure the clock spring was connected to the stalk properly. I also change the servo. Neither helped
Old 24 Feb 2014, 09:48 am
randyincctx's Avatar
Lightbulb Re: 01 Pt Issues
Is the servo getting good vacuum?......If there is a vacuum leak in the cruise control system,it won't work,and the light won't come on if it's not working.
Have you checked to make sure the line to the vacuum reserve canister inside the passenger fender is getting good connection?
omnicrazy likes this.
Aka:~KILLER~
Old 24 Feb 2014, 05:49 pm
I don't have a vacuum gauge.
When I unplugged the vacuum line to change the servo it released a bunch of vacuum then
Old 24 Feb 2014, 07:34 pm
The heat and a/c fan does not work on the second click (low-medium) but works on low, medium-high and high
I replaced the blower motor resistor and the controls themselves. Anyone know how to fix this?
Some issues with my car #2 skolvikes1916 Tech & Performance Forum 1 06 Jun 2011 07:01 pm
Need some help with a few issues! dcsocal General PT Cruiser Discussions 11 13 Apr 2011 07:59 pm
PCM issues I Think ??? Okuma Tech & Performance Forum 4 01 Mar 2011 05:05 pm
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
2 Issues - Need Help 07PTSilver General PT Cruiser Discussions 2 09 Dec 2008 03:45 pm
